Straight AC Will Not Come On - HVAC - DIY Chatroom Home Improvement Forum
Old 04-08-2010, 07:20 PM   #1
Straight AC will not come on
I am working with a 15 year old Carrier weathermaker 8000 2 speed straight AC unit with an A Coil just above the furnace. This unit typically come on automatically every spring when I switch the thermostat to COOL. This spring, it will not come on. After ensuring the batteries in the thermostat were good, I found no juice to the thermostat. After resetting the circuit breaker I found juice coming a switch mounted on the side of the weathermaker. However, this is the switch I use to turn the furnace on and off at the unit so i'm not sure its even connected to the AC.
Where might I find the juice going to the AC and A Coil so I can check that?
What wire would I check if I confirm there is juice going to the AC unit?
Turtle learner is offline   Reply With Quote
Perfectly straight line Casey Flooring 13 04-05-2011 10:18 PM
Repacing HP condenser with straight cool. bama7x57 HVAC 0 07-26-2009 01:32 PM
Shower head leakes, but at least it's straight!?!?! rebaths Plumbing 10 02-03-2009 06:28 PM
Rigid Metal Straight Threads rjordan392 Electrical 2 06-24-2007 11:42 AM
Walls That Aren't Straight Not Sure Building & Construction 4 12-27-2006 11:55 AM
