Stove Top Vent Question - HVAC - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 11:09 PM   #1
Rewards Points: 180
stove top vent question
I'm re-installing my old stove vent. It has an alum one way valve thing in it so as to stop the air from flowing back in I guess. It's a little bent and doesn't work so well so I want to remove it.
Is there some reason to have a one way valve / stopper thing in the stove vent?
This is the style that has a fan inside the tube and the tube goes thru the roof and has a topper to keep out rain. The fan, tubes, everything else is in great condition and cleaned up well.
KarlJay is offline   Reply With Quote
Old 08-26-2011, 04:18 PM   #2
Sounds like you are talking about a Rangehood over top of your stove. If it is a little 3"X10" flapper, you can remove it IF your vent on outside has one. You are correct about it's purpose - Is a Backdraft damper to stop outside air from blowing into your rangehood.
Tin2Win is offline   Reply With Quote
The Following User Says Thank You to Tin2Win For This Useful Post:
KarlJay (08-26-2011)
Old 08-26-2011, 05:59 PM   #3
Rewards Points: 180
Yea, that's what it is then. Thanks!
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
Vent question TVC15 Plumbing 9 11-17-2010 07:30 PM
Wood Stove Blower question Alan HVAC 6 11-27-2009 09:49 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
To Vent or not to Vent, that is the question debster Roofing/Siding 5 08-10-2009 04:48 PM
