Stove/broiler Gas Valve Help - HVAC - DIY Chatroom Home Improvement Forum
Old 03-02-2009, 10:14 AM   #1
stove/broiler gas valve help
hello, Looking for some help here... I cant seem to understand the difference between a robertshaw safety valve that has a pilot in and out(ts11-k) and the robertshaw valve that has only the pilot out (ts-11j).
I can understand the 11-j valve because the pilot out goes right to the pilot/thermocouple. but I don't understand how to connect an 11-k with pilot in and out...where do they connect to.
thanks
mlee999 is offline   Reply With Quote
Old 03-02-2009, 04:56 PM   #2
HVAC / Plumbing
thanks
A picture is worth a thousand words.. Post some pics if you are able
kenmac is offline   Reply With Quote
Old 03-07-2009, 07:03 AM   #3
An old Tradesmen
Rewards Points: 7,814
Is this about the recall on the TS 11 valve.
If so, they will arange free replacement of it.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 10:49 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
