Stop And Go - HVAC - DIY Chatroom Home Improvement Forum
Old 09-28-2007, 09:24 PM   #1
Rewards Points: 530
stop and go
I have a Heil ( I think) split unit. I have noticed the ac will sometimes stop very breifly then start blowing again. Almost make you think 'did that thing just stop and start again?'. Whats up with that? Replaced the contactor a few months ago.
Old 10-01-2007, 08:47 PM   #2
Rewards Points: 530
No ideas out there on this problem? Contactor letting go? bad connection? Dirty? No ideas?? Bound for me to have a problem no one knows anything about.
Old 10-02-2007, 06:12 AM   #3
Rewards Points: 528
I have a Bryant split system that will also do that. I believe its a normal occurance as the AC system determines what speed the blower will run. If its just a glitch in the system, then it has not harmed anything that I can tell.
rjordan392 is offline   Reply With Quote
Old 10-03-2007, 07:48 AM   #4
No it is not normal. Give me some more details. Is the fan (indoor) shutting down or the condenser or both? when you say briefly do you mean seconds or minutes? if it is just the indoor fan, it is pretty common for the fan control board to intermittantly fail in ICP units (ICP makes carrier, heil, tempstar, bryant and a few others) if it is the Outdoor unit also i would look for a loose connection from thermostat or failing thermostat.
abhac is offline   Reply With Quote
Old 10-03-2007, 03:40 PM   #5
Rewards Points: 530
Just a second or two..maybe. Starts back about as quick as it stops. Not sure if the outside unit is doing too. Last time I cleaned it (outside unit), it did not seem to get as clean as I thought it should get. Shouldn't the water hose run through the coils completely. Haven't had what I thought was really good cleaner in a while. I like it when it foams and lifts the contaminants from the condensor coils.
Old 10-03-2007, 04:04 PM   #6
a clean coil is important but will not cause what you are describing, Determing weather the whole system or just the inside unit shutting down would make a big difference on possible causes.
Old 10-05-2007, 10:42 PM   #7
try running it with auto off on controller and then try 1-3 fan speeds on manual.
I am with ABHAC, you need to determine if the outside is doing it also...Unit could be tripping out on L.P...? if it has an auto re-set L.P
fridgeman is offline   Reply With Quote
Gate Valves or Stop and Waste Valves Rich Plumbing 5 03-03-2014 03:29 PM
What is the best type of door stop for front entry door? KUIPORNG Carpentry 5 06-29-2007 05:23 PM
leaking stop valve farrington135 Plumbing 1 03-31-2007 07:33 PM
Frigidaire Water Dispenser Won't Stop tharper999 Appliances 6 03-22-2007 08:11 AM
