Sticking Limit Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2013, 02:10 PM   #1
PoleCat's Avatar
Rewards Points: 1,646
sticking limit switch
Just lit Ol Smokey up this morning and all went well until it was time for the fan to turn off. I gave the Honeywell limit switch a thump and off she goes. Next cycle the same thing. Then again. Any fix for this or do I need to get a new one? The lightest tap triggers it so it makes me think it may be salvageable.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-23-2013, 03:07 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,816
Nyet. They get weak with age so buy Ole Smoker a new one for a early Xmas present.
Old 10-24-2013, 07:36 AM   #3
PoleCat's Avatar
When I turned it on this morning the dadburn thing worked right for the first cycle and I was sure the furnace fairies had come in the night. But the next cycle she stuck on again.
Old 10-24-2013, 09:13 AM   #4
Hvac Pro
yuri's Avatar
I thought it wuz supposed to be "dadgum" thing.
Ever watch Porter Ridge? Terry is pretty dadgum hilarious. check the Terry stays level headed clip. I hate snakes too.
http://dsc.discovery.com/tv-shows/porter-ridge
The Following User Says Thank You to yuri For This Useful Post:
jmon (10-24-2013)
Old 10-24-2013, 11:29 AM   #5
PoleCat's Avatar
This is an older 4046 and the little dial that you're not supposted to rotate was showing 110 at the index after I had pulled it and it cooled further from the standing pilot heat. I knew ambiemt was mid to low 60s so I moved the on and off set points about 40 degrees higher and it is working fine now. Plus I rotated the dial just to be a dick.
Old 10-24-2013, 01:15 PM   #6
Hvac Pro
yuri's Avatar
and now you may have a completely unsafe and inaccurate limit control which may kill ole smokie. those controls lose accuracy with age as the copper bi metal spring hardens. it may now go to 300F before the limit shuts off, if at all. the limit is a critical safety device so the control should be replaced for safety reasons. we don't want to read about you and ole smokie in the news.
Technow (10-24-2013)
Old 10-24-2013, 02:30 PM   #7
FClef's Avatar
Rewards Points: 160
Those old dial limits have a bimetal temperature sensor coil. That metal will weaken with time. You will eventually have the same problem again, no telling when that could happen.
Limit switches are not expensive. Be kind to your old pal and get him something brand new to play with.
"Human beings can always be relied upon to assert, with vigor, their God-given right to be stupid"
Dean Koontz - Seize The Night
FClef is offline   Reply With Quote
Old 10-24-2013, 02:43 PM   #8
An old Tradesmen
Rewards Points: 6,870
Best thing to do is replace old smokey.
If you don't want to do that, then replace that failing L4064 fan and limit control. Cause its going to either fail again. And next time it could fail that the blower doesn't come on.
Old 10-24-2013, 05:00 PM   #9
Hvac Pro
yuri's Avatar
I saw a limit fail once. Strange what can happen to that plastic drain pain of the ole AC coil. Molten blob of plastic it wuz.
Old 10-24-2013, 10:34 PM   #10
An old Tradesmen
Yeah, and they stick to teh heat exchanger, and really smell up the place for a while after wards.
Old 10-25-2013, 05:06 AM   #11
PoleCat's Avatar
I don't know if age caught up with it or it was cooked to death. Toward the end of the last heating season the high limit was turning the burner off several times a cycle and I ended up having to cut open the plenum and clean off the underside of the A coil. Completely coated with a nasty felt. Never turned the heat back on at that point as Spring had sprung. I did make some substantial improvements to the return air duct and filtering though.
I still intend to replace the control when we get past the unexpected 10K in medical bills that popped up over the last week. As Smokey is getting up in years and may not make it another 42 years I was looking to find a bottom dollar replacement part rather than the gold plated jewel encrusted Honeywell number. Any recommendations on what and where ?
Old 10-25-2013, 08:17 AM   #12
An old Tradesmen
Honeywell and White Rodgers are the makers of that stye of control.
Old 10-25-2013, 09:12 AM   #13
Hvac Pro
yuri's Avatar
my local HDepot had them. around $50 I believe. should be under $75.
Bryant 311AAZ036070 Limit Switch Problem coleary61385 HVAC 5 02-24-2012 05:01 PM
furnace limit switch question diyheat HVAC 29 02-18-2012 07:18 PM
Furnace limit switch jk55 HVAC 5 03-03-2011 04:23 PM
heil 9000 limit switch problem? barryatnewton HVAC 1 01-02-2010 05:44 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
