Sticking Gas Valve - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-14-2012, 08:00 PM   #16
Originally Posted by hvactech126 View Post
The heat exchanger on the OLD furnace should be examined for defects by a professional before you put any money into it. Also, the pilot needs upgraded to include a safety device that shuts off the gas in case the pilot blows out.
ok true thanks for the advice. i figured the pilot needs to be upgraded to a safety one so that goes back to my original question what do i need to get. doing some research i THINK i'm not 100% the new safety valves have a built in regulator. so i would need a new valve with a new pilot assy. that had the thermocoupler. it there a kit to swapp this old stuff out?
wallyo is offline   Reply With Quote
Old 10-14-2012, 08:07 PM   #17
Rewards Points: 582
yes standard combination valve will have a builtin regulator....will have to make a new pilot tube and install thermocupler and maybe new pilot assy ...need to see picture of old pilot assy to see if it will work with conversion...ben sr
Old 10-14-2012, 08:11 PM   #18
Oh just remembered when i bought this house i had a home inspector go over the whole house in the part where the heating system is listed he did say the heating system is original to the house 1959. during his inspection to the furnace he stuffed what looked like a camera on the end of a flexabile wire hooked up to a small laptop up inside above the burners and down the other side. and said for it's age it was well maintained and looks in safe operating condition. so i guess that was the heat exchanger he was looking at.
Old 10-14-2012, 08:15 PM   #19
AKA HVACTECHFW
Rewards Points: 1,208
Inspectors, not to discredit them, are not HVAC professionals. At the very least in my encounters they have no business saying a system is safe to operate or not.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-14-2012, 08:18 PM   #20
this is my pilot burner assy
Old 10-14-2012, 08:19 PM   #21
Rewards Points: 582
honeywell makes a universial pilot assy that will accept a thermocupler from gas valve...that one will not work...
The Following User Says Thank You to ben's plumbing For This Useful Post:
hvactech126 (10-14-2012)
Old 10-14-2012, 08:35 PM   #22
yea i didn't think so... any part numbers of the pilot, valve, thermo coupler you can recomend?
Old 10-14-2012, 08:42 PM   #23
how
Rewards Points: 1,104
There are also adapters for testing thermocouples or attaching float protection to thermocouples which would allow you to keep your present pilot assy.
how is offline   Reply With Quote
Old 10-14-2012, 09:08 PM   #24
Rewards Points: 582
white rodgers 36co3333s1 valve...honeywell bulls eye modelQ34A1082....pilot assy could be a number of ones....left right center honeywell Q314A4586
Old 10-14-2012, 09:29 PM   #25
the way my pilot is lit now it the flame is split in a V. it mounts to the front of the burner assy one part of the flame streight back over the burners the other about 90* to the right to heat the thermal switch on the old pilot. so i guess the same way. i need it to point streight back and to the right where the thermocoupler will get the other part of the flame
Old 10-14-2012, 09:36 PM   #26
Rewards Points: 582
the one I posted will work for you ..its straight back with thermocupler in center...should work...
Old 10-14-2012, 09:48 PM   #27
Rewards Points: 582
this may help
Old 10-14-2012, 09:48 PM   #28
Awesome
Old 10-14-2012, 09:53 PM   #29
Rewards Points: 582
pilot assy
Old 10-20-2012, 01:21 PM   #30
Hey Ben Thanks for all your help. I got all your parts you recomended plus a 3" and 10" nipple from Grainger it cost me about $150.00 I got one of the Plumbing, Heating /Hvac guys from the devlopment i work at come over and and swap it over it took him 45 minutes "no charge" cause i let him hang out in my shop away from everyone when he has to work the night shift. I cant thank you enough Ben two thumbs up to you
Well check valve problem, well question maxalex Plumbing 7 08-21-2016 02:21 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 03:04 AM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 10:49 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
