Step Down Transformer - HVAC - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 07:14 PM   #1
Rewards Points: 35
What kinds of things can cause the 240V/24V, 40VA transformer to burn up? My A/C service guy has no clue.
czars is offline   Reply With Quote
Old 04-16-2013, 07:29 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,124
A short.
Use an ohm meter and measure the load.
Old 04-16-2013, 07:46 PM   #3
Rewards Points: 163
Short would be my guess too. Overloaded too, might have caused a breakdown inside causing the short.
I've seen them go bad in our commercial installs, but not very frequently.
52Caddy is offline   Reply With Quote
Old 04-16-2013, 07:46 PM   #4
An old Tradesmen
Rewards Points: 8,184
There is a short in the low voltage somewhere.
Old 04-16-2013, 09:24 PM   #5
Rewards Points: 582
1 st get a new a/c service guy....then look for short..ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
COLDIRON (04-17-2013)
Old 04-16-2013, 10:11 PM   #6
Rewards Points: 242
which side burned up, primary or secondary
hvac instructor is offline   Reply With Quote
The Following User Says Thank You to hvac instructor For This Useful Post:
Old 04-17-2013, 11:29 AM   #7
Rewards Points: 446
The reason for a transformer failure are most times the hardest to find. They usually fail due to a short in the low voltage wiring somewhere. Because of the low voltage and low amperage the short doesn't jump out and say "HERE I AM!" like high voltage shorts do. No burns or arc marks to help you find the cause leaves you usually tracing every inch of wiring especially wherever it gets close or touches metal.
Then of course there is always the inquisitive teeth of rodents and dogs that sometimes will kill a transformer.
If your service person did a good inspection of every bit of wiring that the transformer supplies and still shrugs saying he has no idea, then he just did what every service tech has or will do in his entire career. What he does next though is what will identify him as either a parts changer or not.
A short that can't be found should be followed up with the installation of a fuse for starters that protects the transformer from future failure due to shorts. That's if there isn't already one installed. The next thing that should be installed are what is called Tattle Tales. These are electrical devices installed in certain areas of the wiring that if the short happens again will at a minimum tell the service tech exactly what section of wiring the problem is in.
Is the fuse and Tattle Tales going to cost you? Yes. But you already paid to have one transformer replaced without a clear answer as to why it failed.
old_squid is offline   Reply With Quote
regarding step up transformer DShdw Electrical 12 09-23-2012 04:51 AM
Low Voltage Transformer Problem dlp710 Electrical 2 07-06-2012 09:56 AM
Help with a Step Up Transformer TheConsumer Electrical 10 11-11-2011 12:44 AM
Hang drywall vertical or horizontal nickm1024cobra Drywall & Plaster 54 03-30-2011 11:37 AM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 07:19 PM
