Steaming in AZ
End of problem!! The AC guys found a leak in the outside condenser in one of the loops. The leak was fixed and refilled so we're no feeling better inside at 62 degrees at the vents and with a little more pressure as well. The high and low pressure lines are feeling more normal as well. Guess the indoor was a little frozen up as well because as soon as they pulled the plug on the outdoor unit the vents from attic started pouring out water. For now this issue is closed and I can press on with my next one. Thanks for all the help!
