Steam Valve Old Steam Radiators - HVAC - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 02:37 AM   #1
I have a steam valve that has a numbered ring which can be tightened or loosened and within the ring a slotted knob which can be turned. Have no clue how to use this valve but I would like the steam radiator to run cooler versus hotter so can I control this by the steam valve?
rose12346111 is offline   Reply With Quote
Old 11-29-2010, 05:27 AM   #2
An old Tradesmen
Rewards Points: 6,492
Thats an adjustable air vent.
The lower the number the slower it vents air out. The slower the rad is to heat up.
Yes, you can adjust it to lower the heat you get from that rad.
The Following User Says Thank You to beenthere For This Useful Post:
rose12346111 (11-29-2010)
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Steam Radiators Problem ouch202 HVAC 3 11-27-2010 10:26 AM
Converting Steam Radiators To Hot Water johnpar HVAC 4 07-30-2008 04:34 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Steam Generator Pressure Release Valve runlikegump Plumbing 2 02-13-2007 08:44 AM
