Steam Radiator Question - HVAC - DIY Chatroom Home Improvement Forum
Old 11-16-2007, 07:21 PM   #1
steam radiator question
The pipes were clanging. So, I took the vents off and water came pouring out. Is that what was supposed to happen?
markg7 is offline   Reply With Quote
Old 11-17-2007, 12:42 PM   #2
Custom Cabinet Maker
NO. There could be couple problems. One is the main vent is plugged, that could be interesting to find:}, or there is blockage in the wet return.
First make sure all radiator vents are working,All valves are open, Also make very sure the boiler is NOT OVERFILLED.
skymaster is offline   Reply With Quote
Old 11-17-2007, 10:05 PM   #3
Boiler
Check the water fill valve. It could be leaking through.
shortyshvac.com is offline   Reply With Quote
steam showers Unregistered General DIY Discussions 11 05-23-2011 04:55 AM
Steam Heat still making banging noises helpless handyman HVAC 101 01-04-2008 04:43 PM
Steam Generator Pressure Release Valve runlikegump Plumbing 2 02-13-2007 08:44 AM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 09:02 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
