Steam Radiator Issue... - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 06:52 AM   #1
Steam radiator issue...
Any ideas?
I have three rooms upstairs with old steam radiators. In one room, the radiator gets very hot and warms the room. In the other two, the radiators were not getting hot at all, and didn't seem to be working.
I replaced the vents on the two that were not working with basic adjustable vents. If I play with them, I can get a small amount of heat from the two other radiators, but nowhere near as much as from the first one.
If I take the vent off completely, the radiators become very hot immediately.
Any ideas?
theskunk is offline   Reply With Quote
Old 01-21-2012, 08:12 AM   #2
MarginallyQualified
Rewards Points: 2,464
In the other two, the radiators were not getting hot at all, and didn't seem to be working. I replaced the vents on the two that were not working with basic adjustable vents.
If I take the vent off completely, the radiators become very hot immediately. If I play with them... I can get a small amount of heat...
Any ideas?
Steam pipes usually run vertically... So,
Are these three radiators all fed by the same pipe?
What is happening with the pipes before getting to the 3rd floor at each location?
Does that include any sort of zone valving? (manually or solenoids)
Old 01-21-2012, 08:37 AM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Are you getting all the air out of the radiators?
When was last time boiler was cleaned out/serviced?
Is there enough water in the boiler?
plummen is offline   Reply With Quote
Old 01-21-2012, 08:39 AM   #4
biggles's Avatar
if your not hearing the steam hissing your not going to heat are the radiators tilted towards the single supply line so the cooled off hi temp water can drain back and whats the cycle pressure on that boiler set at?
Old 01-21-2012, 08:52 AM   #5
plummen's Avatar
Is it a 1 or 2 pipe system?
Old 01-21-2012, 08:53 AM   #6
Thanks for the replies
To answer some of the questions:
1.) The two radiators are coming off of two different pipes. Each appears to have one ( I think) first floor radiator off the same pipe- these two radiators work OK.
2.) There is enough water in the boiler. I last had it serviced last year, and the problem existed prior to and since the servicing
3.) I have no idea to determine the cycle pressure- I have an old Weill Mclain boiler, probably from the early 1970s at best.
I will try to shim up one end opposite the steam pipe and see if that helps-
Old 01-21-2012, 08:55 AM   #7
One main pipe out of the boiler, which then splits to four pipes in the basement before going up to the house
Old 01-21-2012, 09:36 AM   #8
biggles's Avatar
there is not a pressure guage on that boiler... when it is running you should see the control pressure with a setting on the boiler 5psi typical hot and running..on that tilting just a 1/4 strip of plywood will to it..if you have rugs...big nut under each far end footing this is so the super heated water runs back to the boiler
The Following User Says Thank You to biggles For This Useful Post:
plummen (01-21-2012)
Old 01-21-2012, 05:08 PM   #9
plummen's Avatar
So its a 1 pipe system without a return/condensate line coming from other end of radiators?
Old 01-21-2012, 05:11 PM   #10
plummen's Avatar
Just be carefull yanking up on those radiators not to knock something loose
And yes you definately need a pressure switch on the boiler.
Old 01-21-2012, 05:15 PM   #11
plummen's Avatar
Servicing a steam or hot water boiler is not something that should be done just yearly,id flush some water out of the bottem of boiler atleast weekly to keep the trash out of system.
Once you get on top of the maintenance and chemicals for the system you can probably go to bi weekly checks,but no less than once a month
Old 01-21-2012, 05:34 PM   #12
plummen's Avatar
Call me crazy but that picture is confusing me!
The way the boiler is piped in the basement looks like a 2 pipe system with the steam leaving top of boiler and condensate being returned to bottem of tank,but the lines are tied together at first floor
Old 01-21-2012, 05:41 PM   #13
MarginallyQualified
didn't you know that MC Esher was also a steam fitter?
The way the boiler is piped in the basement looks like a 2 pipe system with the steam leaving top of boiler...
It's a one pipe "distribution" system...
...and condensate (loop sneakily hidden in the basement) being returned to bottom of tank...
Nope... well, sorta. Look closer.
I believe a check or something goes in at that point
(all that detail aside... the purpose was to demonstrate to the OP that even though the radiators are all on the 3rd floor it's highly unlikely they all share the same pipe routing to get the steam to their 3 different locations)
Skunk: Take a few minutes and draw up your own piping diagram.
Old 01-21-2012, 05:57 PM   #14
plummen's Avatar
Didnt notice any check valves i guess!
Most systems I work around are of the 2 pipe variety with a condensate pump in basement to return to bottem of boiler
Old 01-21-2012, 08:24 PM   #15
Any ideas?
Any ideas?
What is a basic adjustable vents? In the top of the radiator is a steam air vent, is that what you are saying you replaced? It would not be adjustable. Do you have balancing valves where the pipe enters the radiator? Is the diagram that i am looking at , your system. Paul
paul52446m is offline   Reply With Quote
Steam engines Red Squirrel Green Home Improvement 8 04-24-2011 05:59 PM
Steam Valve Old Steam Radiators rose12346111 HVAC 1 11-29-2010 04:27 AM
Seals on steam shower doors hacksepe Building & Construction 1 04-22-2010 05:13 PM
Steam to Hydro Air Conversion RBR HVAC 1 09-17-2009 04:23 PM
Converting steam heat to hot water??? pcampbell HVAC 31 02-17-2009 08:26 PM
