Steam Heating System In An Old House. Do I Add Water, And Where? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-23-2010, 10:14 PM   #1
Steam heating system in an old house. Do I add water, and where?
Hey guys, we just bought a 1921 four square house. Brick, 2,144-square feet. The entire house is heated by a steam system. Below are photos of the unit. I've never used one of these before, but I understand water must be added manually on some. The seller mentioned that this one runs off of a water line in the house. The water is off at the moment pending some plumbing work in early January. Since I can't tell if the water must be on to operate this heating system, we've had the heat off, too. That's not ideal here in Ohio in Winter, we have space heaters all over the place to keep the house warm. Anyway, do I add water manually, and where? How much? I can't tell! The seller assumed it was connected to the water line, and implied that it should be left off when the water is shut off, but she's an elderly lady that didn't give me the impression that she knows much about the mechanics of the house. But I don't know much either!
Steam heating system in an old house. Do I add water, and where?-house52.jpg   Steam heating system in an old house. Do I add water, and where?-house53.jpg   Steam heating system in an old house. Do I add water, and where?-house54.jpg   Steam heating system in an old house. Do I add water, and where?-house55.jpg   Steam heating system in an old house. Do I add water, and where?-house57.jpg
Steam heating system in an old house. Do I add water, and where?-house66.jpg
Salvatorparadise is offline   Reply With Quote
Old 12-23-2010, 11:03 PM   #2
From some research this evening, I now believe this is a hot water heat system, and that it is tapped into the water of the house.
Old 12-24-2010, 05:51 AM   #3
Yes it is a hot water boiler. Be careful with that pipe insulation, it looks like asbestos and should be covered or professionally removed.
fitter1 is offline   Reply With Quote
