Steam Heat Pipe Size? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-24-2007, 07:31 PM   #1
I have a 2 inc supply line, whats the correct size of pipe for the water return line?? Thanks!
helpless handyman is offline   Reply With Quote
Old 11-25-2007, 10:48 AM   #2
Custom Cabinet Maker
Normally 1 1/4 wet return, 2" main? what size header?
skymaster is offline   Reply With Quote
Old 11-25-2007, 04:58 PM   #3
Thanks Skymaster, that's what I wanted to hear. I have a 2 inc supply, and had a 1 inc water return, didn't seem to do it. It was taking to long for the water to return to the boiler, and the auto feed was kicking in. I changed it today to 1 1/4 and it seems to be working okay, but time will tell. Thanks
Old 11-25-2007, 05:44 PM   #4
Also be sure there is a vent in the main. Should be there when system was first done, find it and be sure it is working, if any doubts replace it with one of identical size ( venting wise). It will look like a radiator vent but on steroids :}:}:}:} usually 1/2 or 3/4 IP.
Old 11-25-2007, 07:02 PM   #5
Thanks, took care of that I installed a new one while I was doing the pipes, 3/4 steam pipe vent!
Old 11-25-2007, 08:10 PM   #6
Damn, how could I have guessed that? LOL LOL
Glad it worked out. Enjoy
Jack
Steam Heat still making banging noises helpless handyman HVAC 101 01-04-2008 03:43 PM
change steam radiant heat to outside wood water heat Monteu HVAC 5 02-13-2007 11:19 AM
Leaky Steam Heat Pipe NJE HVAC 6 01-30-2007 08:26 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 08:57 PM
