Steam Heat Main Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 02-27-2010, 11:50 PM   #1
My (old) house has a one-pipe steam heating system. The main vent is at very the end of the steam supply main, on a tee in line with the vertical pipe that starts the wet return. Everything I've read says that the main vent should be about 15 to 18 inches before (that is, upstream of) the end of the steam supply main, not at the end.
Ques.1: How am I hurting by leaving the vent where it is; why is 15 to 18 inches better than zero inches? What is gained by relocating the vent?
Ques.2: How big a job is it to tap into the 2-inch supply main?
Thank you for your answers.
sizzz is offline   Reply With Quote
Old 02-28-2010, 04:59 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 310
I have found this site to be most helpful for my steam heating questions
http://www.steamforum.com/steamforum_reg.asp
chrisn is online now   Reply With Quote
Old 02-28-2010, 09:22 AM   #3
Licensed Master Plumber
Change your point of view. The system was installed at least 50 years ago, probably a lot longer actually. The guy that installed it new what he was doing. ( it came with the terratory back then) Unless someone has messed with the system, leave it alone. If you think you are having delivery issues....
Bad radiator vents
Bad main vents
Clogged or partially clogged return piping
Wrong pressuretrol setting
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 02-28-2010, 09:43 AM   #4
JohnH1's Avatar
15 to 18" is because as the steam and water reach the end the water will basicly slam into the elbow. some water will go down and some up and into the vent causing vent damage. It will work at the end as it already has for years. But the proper location is before the end of the main.
JohnH1 is offline   Reply With Quote
Old 02-28-2010, 02:45 PM   #5
An old Tradesmen
Rewards Points: 6,876
As John said, proper is at around 18" before the end of the main.
As NH said. its been like that for a long long time. No reason to change it now. Unless your replacing teh main vent every year or 2.
Repair or replace gas heat unit and power vent PegTN HVAC 1 11-06-2009 06:40 PM
steam heat problems alanliz HVAC 8 01-18-2009 08:10 AM
No Steam Vent for Dryer Bicycle Junkie Appliances 11 12-09-2007 03:58 PM
Flushing a Steam Heat Furnance helpless handyman HVAC 2 11-06-2006 04:34 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 08:57 PM
