Old 01-31-2009, 03:19 PM   #1
Electrician
Default steam heat issues
I'm new to having an account on the forum but have been reading other peoples questions and answers for sometime now and decided to best describe my situation I should just sign up. I posted this on plumbing too, because I wasn't sure which forum would best suit to help me out.
I have a one pipe steam heat system, with cast iron radiators that switch over from Iron pipe to copper in the basement. The problem is, it's only one zone so the upstairs does not seem to warm up as much as the downstairs. Our friend is staying with us and complains that it gets too cold at night. I have tried insulating the basement pipes, replacing the air pressure relief valve in the radiator itself and it still doesn't get warm enough.
I guess the problem is I'm trying to get the heat warmer without having to re-pipe the basement and put the upstairs on a new zone.
Any suggestions?
raggedbeefman is offline   Reply With Quote
Old 01-31-2009, 03:28 PM   #2
old pro
Are the radiators upstairs getting hot? On a one pipe system it is very important that they be sloped slightly towards the end where the steam comes in or the condensate won't drain back properly. Raise the other end with a thin shim ( 25c/quarter) may be all it takes. Floors sometimes settle. Other posters have done this. Start with the simple tricks B4 repiping.
Old 01-31-2009, 03:36 PM   #3
Electrician
Thanks, I'll try that out, the pipes in the radiators are getting hot, it just doesn't seem like the blow out enough steam. I opened the valves up to let more out, and I heard the high pitched whistle letting air out when we moved in...I'll try to raise up the end with the valve on it to see if that helps.
Will post later on when the heat kicks on to say whether or not it worked
Old 01-31-2009, 03:44 PM   #4
old pro
Raise the opposite end to the valve.
Old 01-31-2009, 04:09 PM   #5
Electrician
it's pitched upward away from the floor, is that right?
Old 01-31-2009, 04:31 PM   #6
old pro
If the valve is on the right side when facing the rad, then the left side needs to be higher. When the steam gives up its heat it condenses into water which needs to drain back to the boiler. If not it gets "waterlogged" and more steam cannot enter.
Old 01-31-2009, 04:37 PM   #7
Electrician
ah, gotcha. The left side is where the pipe goes back towards the boiler, the valve is on the right side? Is the valve in the wrong place?
Old 01-31-2009, 04:41 PM   #8
old pro
Post a pic of it here. The one pipe system that I have seen only has a pipe on one end with a special fitting. I am not an expert on them. "Beenthere" seems to know a lot about them. Saw a episode of "This old house hour" where they recommended elevating the rad as the floor had sunk over time. Click on his name and send him a message if he does not see this post.
Old 01-31-2009, 05:36 PM   #9
Electrician
here is a picture of one of the upstairs heaters. Is there anyway you can upload and highlight where to elevate?
Old 01-31-2009, 06:07 PM   #10
An old Tradesmen
Thats a convector, not a radiator.
Is that vent adjusable?
Are any of the vents on any of the convectors adjustable.
If they are adjustable. Turn all the vents on the seond floor to their max open position.
May need to turn some of the vents on the first floor closed a little. May want to close the one in the room wth the stat more then the others.
Also, is there a main vent in the basement. Make sure its working.
Next, what pressure is the boiler operating at. make sure its NOT going aove 2PSIG.
Old 01-31-2009, 08:44 PM   #11
Electrician
I've opened the vents all the way on the first floor and closed the ones as low as possible near the stat downstairs. Also checked the vents out. Boiler is lower than 2psi. I also insulated the pipes downstairs that carry the heat to see if maybe too much was escaping. The steam pipe going into the convector is very hot, but still does not seem to push out much steam, i even replaced the relief valve in it.
Old 01-31-2009, 08:54 PM   #12
An old Tradesmen
I hope you mean you opened all the ones on the second floor.
Turn the stat up and remove the vent on the convector that isn't getting hot up stairs.
See if it gets hot then. The pipe to the vent may be clogged, with rust.
Old 01-31-2009, 08:58 PM   #13
Electrician
will water come out of the vent when i take it off?
yes, i did mean the ones on the second floor, sorry about the error.
Old 01-31-2009, 10:39 PM   #14
An old Tradesmen
If water comes out, you have a real problem.
Shouldn't have any water come out, All the water should be draining back down the pipe to the boiler.
Old 01-31-2009, 11:07 PM   #15
Electrician
alright I'll give it a shot and will repost with results.
More On This Topic
Anyone living with large, steaming hot radiators in their home will eventually think of replacing them with something smaller and cooler. A simple solution is to replace your radiator with a smaller, less sizable convector. Here are the steps to replace... Read More »
This is Shannon Kniep on behalf of Expert Village. Before you put your sheetrock on, you want to go ahead and make sure that you've got everything taken care of because you're going to cover it up. In this case, we need insulation on our pipes--this is a... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. One thing to remember when plumbing your basement, is that the location of the toilet is not as important as it first may seem. Where that pipe is sticking... Read More »
How to Iron Blue Jeans
How to Iron Blue Jeans by Expert Village
Hi, I'm Marti. On behalf of expertvillage.com I'm going to share with you today how to press a pair of pants. We are going to be pressing a pair of blue jeans using starch. I also have a press cloth that if I need I can use it's a simple cotton cloth... Read More »
How to Iron Pants
How to Iron Pants by Expert Village
Hi! I'm Joyce Danielson for Expert Village. Turn the pants inside out, look for the tag that gives ironing and information for the garment. Change the heat setting on your iron appropriate for the fabric. Linen and 100 percent cotton take a high setting... Read More »
Converting steam heat to hot water??? pcampbell HVAC 31 02-17-2009 10:26 PM
Top floor heating issues. Steam heat system. topfloornoheat HVAC 4 12-06-2008 03:33 PM
Single Pipe Steam Heat (Please help) jpic Plumbing 2 11-20-2008 09:51 AM
Steam Heat still making banging noises helpless handyman HVAC 102 01-04-2008 05:43 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 10:57 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
