Steam Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-07-2010, 03:29 PM   #1
steam heat
only a portion of my radiator gets hot
jspans8 is offline   Reply With Quote
Old 01-07-2010, 04:36 PM   #2
An old Tradesmen
Rewards Points: 6,836
Is it a single or 2 pipe system.
Old 01-07-2010, 05:20 PM   #3
tk03's Avatar
Rewards Points: 150
That may not be a problem. There is no rule that says the radiator must heat all the way across. As homes with steam systems tighten up the rads will normally heat less sections. Is the home warm?
tk03 is offline   Reply With Quote
Old 01-07-2010, 07:00 PM   #4
Learning by Doing
Leah Frances's Avatar
This may or may not be a problem. If you have hot water heat (two pipes on the radiator) it IS a problem.
May not be a problem: Your thermostat reaches the ordered temperature before the radiator has time to heat all the way across - then your boiler shuts off.
May be a problem: (single-pipe info) Is your boiler still running, but the radiator is only partially hot? If yes, you have a problem.
Are your supply valves all the way open? With single pipe heat, are your main vents working? The radiator might be gunked up - when's the last time you blew down your boiler? Is it pitched correctly? The vent may not be working correctly. Properly functioning vents to no whistle, hiss, or spit. If it's not venting efficiently or quickly enough you have the same situation as 'may not be a problem' (this can be corrected and you can heat your space faster and by burning less oil).
On the coldest day of the year all your radiators should get 'hot' at the same time. If your boiler is still sending heat your radiator should heat all the way across.
I reccomend going to www.heatinghelp.com it is the BEST site for information about steam heating. Read Dan Holohan's books.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-08-2010, 09:34 AM   #5
thanks for the info
Things seem to go better last night. I usually keep the thermostat on 62 deg.
but last night I turned it up to 64 and all the radiators kicked on at the same time and heated all the way thru.
Not sure if that was the problem-thermostat too low? The pipes in the basement are rapped so they shouldn't be cold enough to slow the steam.
any help?
Old 01-11-2010, 08:28 AM   #6
tk03's Avatar
Rewards Points: 150
Here is a link to FAQ about steam heat.
http://www.comfort-calc.net/Steam_FAQ.html
Old 01-11-2010, 09:41 AM   #7
In houses where additonal insulation and windows have been added, and thermostats added to the radiators, they may not be hot all the way accros. But only near the thermostat valve.
H. Phillips is offline   Reply With Quote
Converting steam heat to hot water??? pcampbell HVAC 31 02-17-2009 08:26 PM
Single Pipe Steam Heat (Please help) jpic Plumbing 2 11-20-2008 07:51 AM
Steam Heat still making banging noises helpless handyman HVAC 101 01-04-2008 03:43 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 08:57 PM
