Steam Boiler Need Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 02-28-2011, 04:15 PM   #1
steam boiler need replacement
hi,
I have just purchased an older home (1790), which is equipped with two steam boilers. Both of them need to be replaced, plus 2 of the insanely-heavy cast iron radiators are cracked. At first glance, it could be possible to link both systems and operate on only one boiler. I'm no HVAC expert and need to look at all my different options, and its quite overwhelming, frankly.
I'm sure there are retro-fit or so options available out there, and since i need to replace the boilers anyway, i'd like to invest in an updated, energy efficient, eco-friendly alternative that could save heating costs and energy, while adding to the value of the house.
Anyone with a vision? or the foundation of a solution?
techsavy is offline   Reply With Quote
Old 02-28-2011, 05:06 PM   #2
It's something that has been done before. I'm sure a qualified expert can guide you in the right direction. Not to worry.
D
StahlMaster is offline   Reply With Quote
Old 02-28-2011, 05:29 PM   #3
An old Tradesmen
Rewards Points: 6,870
Are they single or 2 pipe systems?
Tags
hating , hot water , steam boiler
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Steam heat Boiler burns, steam doesn't travel? tomhere HVAC 18 10-16-2010 03:01 PM
Cost of boiler & cylinder replacement abaminog Off Topic 9 03-31-2010 07:05 PM
Steam boiler replacement mindcandy30 HVAC 3 12-10-2009 02:13 PM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 08:02 PM
