Steam Boiler/ Baseboard Hook Up In Basement - HVAC - DIY Chatroom Home Improvement Forum
Old 11-04-2011, 08:16 PM   #1
Steam Boiler/ Baseboard hook up in basement
Hi all,
I have a steam boiler, and I would like to connect some hot water baseboards to it in the basement level, to warm up the basement. I see other people do it, they run baseboard around the basement, then they tap into the boilers hot water, hook up a thermostat, pump and relay. Can it be done?
I have a very good idea where the hook ups go, just not familiar what relay to use and how to hook it up to the thermostat and pump?
Thanks to all
helpless handyman is offline   Reply With Quote
Old 11-04-2011, 10:11 PM   #2
biggles's Avatar
this would be a typical relay with a 24v coil to have the stat control it, and have the relay control the pump thru the N.O. contacts. wire the pump direct 115V then break the hot wire thru N.O. relay contact.stat wiring will be R to W with an add on transformer 40VA 115V/24V.TR HOT to R on the stat W out to relay coil other side to C on TR .might cheat 24V off boiler check VA on units TR
Old 11-07-2011, 09:30 AM   #3
Thanks biggles, I already bought the pump and the thermostat. Can you tell me where I can purchase the 24 relay? Model number or link would be awesome.
Thanks again
Old 11-08-2011, 08:35 AM   #4
Can anyone recommend a relay I can use to wire the thermostat and circulating pump?
Thanks!
Old 11-08-2011, 07:19 PM   #5
An old Tradesmen
Rewards Points: 6,550
Honeywell R845A.
Old 11-08-2011, 09:56 PM   #6
Beenthere, like that name
This is new to me, haven't been there. Where would I connect the thermostat wires, power to relay, power to pump?
Old 11-08-2011, 10:07 PM   #7
Will a Taco 1 Zone switching relay SR501-2 do the same trick?
Old 11-08-2011, 10:32 PM   #8
An old Tradesmen
Yes it will work.
Old 11-08-2011, 10:44 PM   #9
How hard will this be to wire up?
Old 11-09-2011, 05:01 AM   #10
An old Tradesmen
Its not hard at all. Very easy. Run the 120 volt line to relay, connect circ to relays terminals, connect thermostat to relays TT terminals, done.
Old 11-09-2011, 08:16 AM   #11
THANKS BEENTHERE
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Basement wall framing with baseboard heaters gregkfraser Building & Construction 3 11-14-2010 10:35 PM
Coverting from Steam to Hot water Boiler ericm215 HVAC 1 05-23-2010 11:03 PM
Steam Boiler Recommendations.... helpless handyman HVAC 1 01-28-2009 08:53 PM
