Old 01-25-2012, 12:36 AM   #1
steam boiler
My steam heat boiler is not making heat come up fast enough to radiators and when the radiators start feeling warm they never get fully hot. Only a small portion of the radiator will get hot. This only started happening about a week ago. I went to look at the boiler and i noticed the pressure gague never moves off 0. The boiler doesn't also doesnt seem to be as loud when the water is boiling. I was thinking maybe it could be the gas valve went bad and not creating enough fire. So i increased the pressure on the gas valve but i dont see any difference. Then i incresed the inlet and outlet but no difference. So then i then decressed everything and still didnt see any change. Now since i see no pressure on the gage and it doesn't seem as if any any changes occur with the fire when i decrease or increase the pressure on the gas valve, does that mean the gas valve could be busted.
PS i already checked the pressure valves on the radiators and on the main and they are fine.
frank717717 is offline   Reply With Quote
Old 01-25-2012, 12:41 AM   #2
steam boiler
steam is a dangerous source of heat if not properly maintained........I know this is not what you want to hear, but its the right thing to say............get a pro to look at it, or risk being at the least seriously burned and possibly blown into tiny pieces.
harleyrider is offline   Reply With Quote
Help With Steam Boiler bpm HVAC 7 10-08-2011 09:29 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
Steam heat Boiler burns, steam doesn't travel? tomhere HVAC 18 10-16-2010 04:01 PM
Coverting from Steam to Hot water Boiler ericm215 HVAC 1 05-23-2010 11:03 PM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 09:02 PM
