Old 11-22-2007, 06:52 AM   #1
steam
Send a message via Yahoo to steam
steam
i have a problem with my outside wood boiler I have a home made boiler closed system with water capasity of about 50 gals but the stove i welded the the heat tank to is bigger stove than my old one when i hooked it up an started heating it it over heated not enough water volume so i got a old feuloil tank plumed it to my systemworked great till it got to temp bout 150 deg's then the tank smeled up an split seem bout 4or 5 psi is the tank not strong enough or what plaese reply thanks
steam is offline   Reply With Quote
Old 11-22-2007, 07:47 AM   #2
steam
If you're just using water, maybe a glycol mix to lower the boiling point would help? Aside from that, water / steam causes pressure to build, is there a temp/pressure relief valve in the system?
LawnGuyLandSparky is offline   Reply With Quote
Old 11-22-2007, 07:54 AM   #3
steam
steam
yes 30psi but tank swelled up at 4or5 psi at 150 deg's should i get a stronger tank one made for presure i split one allready this is secound one
Steam Heat still making banging noises helpless handyman HVAC 101 01-04-2008 04:43 PM
Steam Generator Pressure Release Valve runlikegump Plumbing 2 02-13-2007 08:44 AM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 09:02 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
