Static Pressure: Rule Of Thumb? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-26-2008, 02:47 PM   #1
Rewards Points: 528
Static Pressure: Rule of Thumb?
Hello,
I want to boost the cfm output in a 4 inch duct by 50 to 100 cfm that comes from my bathroom blower fan with a booster fan. The existing run of the duct plus 4 elbows has cut back on the rated cfm of the blower which is rated at 270 cfm free air. Now depending on the static pressure value of 0.05 to 0.375, the cfm will be from 250 to 70 cfm.
So how does one calculate by rule of thumb, the static pressure near the end of the duct run which is probally where I will install the booster fan? If I can determine the approximate static pressure, then I will know the approximate cfm delivery at that point and be able to pick out the correct booster fan.
To complicate matters, the dischage flange of the blower housing is 3-1/4 by 10 inches and I used reducing adapters down to 4 inch round duct because the duct run has to go through a 4 inch opening in my concrete foundation. Now I can increase the size of the duct run for most of it but still need to reduce it to 4 inches to go through the foundation wall. Can this be solved?
rjordan392 is offline   Reply With Quote
Old 06-05-2008, 08:47 PM   #2
hmmmmmmmmm
ro9beam2002 is offline   Reply With Quote
Old 06-05-2008, 08:52 PM   #3
Rewards Points: 150
Originally Posted by ro9beam2002 View Post
hmmmmmmmmm
i agree,,, haven't a clue
comp is offline   Reply With Quote
Old 06-06-2008, 04:54 AM   #4
How big is your bathroom? 270 cfm is quite a bit of air.
try this site. they have some sizing program called compute-a-fan. http://www.lorencook.com/About/destools.shtml
Chimichanga31 is offline   Reply With Quote
Old 06-06-2008, 12:55 PM   #5
Rewards Points: 528
I solved my problem by installing a light/fan/timer switch. The timer can be set for up to 60 minutes and has a preset adjustment in the switch. The bathroom is 9 x 8 x 7 foot. It takes a while to vent it properly due to the resistance to air flow in the ducts. I set the timer to run an additional 10 minutes after each use of the bathroom.
rule of thumb for tamping backfill elementx440 Remodeling 5 05-30-2013 11:46 PM
fittings and pipes sizes.. effect on pressure? cgerikh Plumbing 3 05-19-2008 10:37 AM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
Pool Motor Wiring Assistance tazmajazz Electrical 18 05-16-2008 10:42 PM
Pressure Fluctuation with well water beertestr Plumbing 5 10-03-2007 09:18 AM
