Static Pressure Question - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 11:41 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 68
Static pressure question
This is more a theoretical question, not really about anything specific.
Lets say I have a fan or blower that is pushing air through a 8 foot spiral hose. That hose creates a certain amount of static pressure that the blower has to run against.
Now if I add another idential 8 foot spiral hose on the intake side of said fan, does that increase the static pressure more, or does it just equalize because there's already "forward" static pressure? Basically if you have a 16 foot air hose, is it more effective to put the blower in the middle then at either end, or does it not matter?
Old 07-15-2010, 07:23 AM   #2
An old Tradesmen
Rewards Points: 6,500
TESP, is accumulative. Adding another 8' increases the static. Weather you add it to the return or to the existing 8'.
However. If you add that hose to the return. The static in the supply would decrease, because you increased the return static.
Water Pressure Question jamiedolan Plumbing 6 08-16-2009 01:43 PM
well pump wont hold pressure jakjkl Plumbing 6 12-20-2008 10:11 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
new Infinity system shows static pressure at 0.09 peterv HVAC 5 12-07-2008 01:22 PM
Pressure Balanced faucet question scp Plumbing 2 01-07-2007 06:15 PM
