Old 01-21-2011, 04:20 PM   #1
Static Pressure Diagnostic Testing
Watch this video (both parts). Have you ever seen your HVAC company perform this important diagnostic test on your system?
For me, No.
http://www.youtube.com/watch?v=YkCXg...eature=related
Earnie is offline   Reply With Quote
Old 01-21-2011, 06:06 PM   #2
An old Tradesmen
Shawn is a tech rep, and he made a good video there. With 1 minor mistake. I brought it up to him. He won't admit it though.
Old 01-21-2011, 06:20 PM   #3
hvaclover's Avatar
You mean where he inserts one of the pitot tube tip in the wrong direction to the air flow?
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 01-21-2011, 06:40 PM   #4
An old Tradesmen
No, he's using A303 static probes. The holes are on the sides, so they can point either way.
Its not what he did, as much as what he said.
Old 01-21-2011, 06:47 PM   #5
hvaclover's Avatar
I read the post where he got busted on the probe.
Old 01-21-2011, 07:03 PM   #6
An old Tradesmen
The probes he is using in that video can be pointed with or against the air flow. makes no difference. I use the same probes,and have turned them while checking units. Same reading in either direction.
Pitot tubes would be a different story.
Old 01-22-2011, 08:49 AM   #7
Many times Earnie. Static pressure readings are part of our start up check list on all new equiptment. Didn't used to be that way but about 10 years ago the electric company required TESP on the rebate forms as part of the heat pump performance verification. That really opened my eyes so besides start up the magnaghelic comes out any time a problem is showing a possible air flow issue.
Old 01-22-2011, 11:04 AM   #8
Hi Marty,
That is good to hear.
I have been through three Trane Comfort Certified companies and non have checked SP. These were companies that had never looked at my system before. You would think that being called to a new customers house you would want to do a thorough system check.
Most of the time all I have seen them check is coolant pressure. One did check amp readings. No one checked SP or air flow at each room supply.
It's unfortunate that I have to learn about HVAC to make sure my system is operating efficiently.
Testing new plumbing with air pressure Niffumdutz Plumbing 22 06-19-2011 04:35 AM
Static pressure question Red Squirrel HVAC 1 07-15-2010 07:23 AM
Static Pressure befor filter or after key1cc HVAC 33 11-23-2008 10:56 PM
Carrier 58MVC low static pressure alarm diy12345678 HVAC 1 11-06-2008 09:21 PM
Static Pressure: Rule of Thumb? rjordan392 HVAC 4 06-06-2008 01:55 PM
