State Of The Art Gas Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 08-30-2009, 10:08 AM   #1
Hvac Pro
yuri's Avatar
Rewards Points: 380
State of the Art Gas Boiler
Check out the Ultra Series 3 (modulating) boiler:
http://www.weil-mclain.com/products/...ired%20boilers
http://www.weil-mclain.com/downloads...ler_manual.pdf
Beenthere and Plumber 101 may be especially interested. Uses a similar negative pressure modulating gas valve as the Lennox G71, Sweet technology.
Old 08-30-2009, 06:10 PM   #2
An old Tradesmen
Rewards Points: 8,142
I started installing the Ultra, back when it was Sereis 1.
Great boiler, easy to install.
Old 08-30-2009, 06:32 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
I'll have to keep this in mind. I only service three boilers in my area. Not very popular here.
Yuri
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-30-2009, 06:33 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 380
Looks really interesting. Can be wall mounted. Preconfigured for outdoor reset etc etc. There are now ECM circ pumps available, which will work better when several zones are off. Great technology.
Old 08-31-2009, 02:08 PM   #5
JohnH1's Avatar
They must be set up with a combustion alalyzer. Just finished this one.
JohnH1 is offline   Reply With Quote
Old 08-31-2009, 04:23 PM   #6
Does this use a t'couple to detect a flame fault? I didn't see one on the parts list.
Old 08-31-2009, 06:06 PM   #7
An old Tradesmen
No it doesn't.
Old 08-31-2009, 08:45 PM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 380
Nice install John. The gas valve modulates so you would need a combustion analyzer. I like the high end stuff. Keeps me real busy as the dummies are scared of it and not motivated enough to learn it.
Old 09-01-2009, 02:49 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 380
Yoyzie it uses a TWR.
Old 09-01-2009, 09:10 PM   #10
Which is. . .?
Old 09-01-2009, 09:26 PM   #11
Hvac Pro
yuri's Avatar
Rewards Points: 380
thermal wave rectifier
Old 09-01-2009, 09:34 PM   #12
Uses the elec. conductivity of the flame? Gets false alarms?
Old 09-02-2009, 05:49 AM   #13
An old Tradesmen
Nope.
The flame is very stable.
The burner modulates, but the flame is stable under its full modulation.
Circulation pump on boiler uncleneiler Plumbing 4 06-22-2010 09:01 AM
Outside water boiler shutdown hillardl Plumbing 2 03-20-2009 05:27 PM
Tankless coil in oil-fired boiler lebeld Plumbing 4 01-18-2009 08:48 AM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 08:26 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
