Starving AC System & Flexible Duct Pricing - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-03-2009, 09:39 AM   #16
An old Tradesmen
Rewards Points: 8,174
A 12" with a return from your bedroom and another area would work fine.
Only making it a 10" from the unit, woul increase the 16" velocity since you would still be pulling 1200 plus CFM through it.
Old 09-03-2009, 10:31 AM   #17
Could you elaborate on this a little? ...The little mice running around my head are having a hard time grasping this concept.
deeze is offline   Reply With Quote
Old 09-03-2009, 11:26 AM   #18
An old Tradesmen
Run a 12" from the return plenum of the air handler. To the general area where the second return in the hallway will be. From that point, you can run an additional return line to your master bedroom if you want.
Bedrooms generally only require their own return. When the door is closed, and the door is not undercut. Or undercut enough.
Old 09-03-2009, 02:02 PM   #19
GC/Master Plumber/Mech
Rewards Points: 560
Good point you made Been. I didn't even think he may have a 5 tn blower.
Thanks for your imput Been
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Openings in air intake duct on central HVAC system Omegazz HVAC 5 04-01-2010 12:59 PM
flexible duct bingo HVAC 1 09-13-2007 09:54 PM
New flexible air duct co20070904 HVAC 3 09-05-2007 09:32 AM
Clean Duct System? Devil505 HVAC 9 12-07-2006 08:33 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 10:56 AM
