Starting Up A Goodman Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2008, 06:55 PM   #1
Smile
Starting up a goodman furnace
I turned off my goodman furnace last year and when attempting to start it this year have been unsuccessful so far. I followed the startup directions but it does not startup. It does not fire up. Any suggesstions would be appreciated. Numbers off the label:
GMP 100-5 REV A...9709806142
It worked fine last year but nothing when I attempt to start it this year.
Any suggestions would be appreciated.. Thanks, Mike in Tucson
MikeS is offline   Reply With Quote
Old 12-08-2008, 07:54 PM   #2
Do you have electric,fuel (gas)? If you do then by shutting the system down for a period of time you may have to reset a switch -- I had trouble tying to down load info on your unit
NYCtinman is offline   Reply With Quote
Old 12-08-2008, 09:53 PM   #3
it's an old Junkatrol 90%.
Check your breakers for the furnace. They may be off.
hvaclover is offline   Reply With Quote
Old 12-10-2008, 05:01 PM   #4
Thanks for the response to my post from MikeS in Tucson
I appreciate your suggestion but unfortunately that is not the problem. Money is very tight now with the holiday and it sure is getting cold at night even here in arizona. Am trying to do it myself. Thanks, Mike
Old 12-10-2008, 05:35 PM   #5
If there is a clear window on the bottom panel, can you see a red light on the circuit board. If you don't see a light there is no power to the circuit board. Also if the bottom panel is off or loose the furnace will not run.
SKIP4661 is offline   Reply With Quote
Old 12-10-2008, 05:47 PM   #6
Skip...thanks for the response
I see no light but have the safety switch not even attached as it is a used furnace which did not have a switch installed. I have one but am not sure how to install it. The furnace worked fine last year without it. I have shut it down, waited but still have nothing that fires up. Any suggestions would be appreciated mike
Old 12-10-2008, 07:42 PM   #7
Its sounds like an electrical problem. Check the breaker, test to see if you have power at the furnace, power coming to the switch and after the switch.
Also check the thermostat for power (low voltage)
Goodman Furnace gas firing but shuts off digitaljim HVAC 3 12-08-2008 03:29 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Goodman Furnace does not kick in wctoro HVAC 2 02-20-2008 01:47 PM
goodman furnace nhicks HVAC 3 02-09-2008 06:25 PM
Goodman furnace not starting cathyfc HVAC 1 10-05-2005 11:35 AM
