Starting Issue W/Miller Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 08-12-2011, 07:41 PM   #1
bgbrown125's Avatar
Rewards Points: 27
Question
Starting Issue w/Miller Heat Pump
I was working outside next to my Miller Heat Pump the other day and I noticed that when it starts up, it seems to take 2 or 3 attempts to get the compressor operating. After niticing this, I notice that you can tell the power consumption cut in & out when it is starting up on my bedside light (bright -dim). Once it is started it works great and this does not occur at every startup.
What can I do to address this issue.
Thanks in advance
Barry
bgbrown125 is offline   Reply With Quote
Old 08-12-2011, 07:43 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
replace the capacitor and add a hard start kit
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
bgbrown125 (08-12-2011)
Old 08-12-2011, 07:54 PM   #3
I would also check all of the electrical connections from the breaker box to the contactor.
Master of Cold is offline   Reply With Quote
Old 08-16-2011, 08:29 PM   #4
bgbrown125's Avatar
Rewards Points: 27
Ok. Given the attached pictures' information, what exactly do I need to purchase from Granger Company?
Thanks again
Old 08-16-2011, 08:30 PM   #5
bgbrown125's Avatar
Rewards Points: 27
Did that....nothing found and the pushing to ensure contact had no effect.
Old 08-16-2011, 08:46 PM   #6
JJboy's Avatar
Thanks again
You need hard start kit for 3 Ton unit. The capacitor you need to see the MFD value.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-16-2011, 09:23 PM   #7
bgbrown125's Avatar
Rewards Points: 27
Where do I find the MFD at?
Old 08-16-2011, 09:27 PM   #8
JJboy's Avatar
if you're lucky, on the body of this rusted capacitor.
Old 08-16-2011, 10:10 PM   #9
AKA HVACTECHFW
you would need to call a nordyne dealer/wholesaler and give them the model and serial so that they could tell you what value capacitor is needed.
IT IS WHAT IT IS
Old 08-16-2011, 11:37 PM   #10
Rewards Points: 338
here's a pdf of the parts list online for your series of heat pumps:
http://www.centraltrailer.com/resour...T3QC_MT3QC.pdf
capacitor is part number 620763 which shows up as a 40+5 dual run capacitor.
NitroNate is offline   Reply With Quote
Old 08-17-2011, 07:37 AM   #11
bgbrown125's Avatar
Rewards Points: 27
Thank you so much
Barry
Old 08-17-2011, 07:38 AM   #12
bgbrown125's Avatar
Rewards Points: 27
You guys ROCK!
Thanks for the information.
Barry
Frost around pipe from Heat Pump to furnace stumpw HVAC 5 04-10-2010 09:45 PM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 03:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 02:11 PM
