Standing Pilot Gas Usage - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-24-2008, 07:19 PM   #16
Rewards Points: 292
Originally Posted by Martinglmt View Post
I have info on gas fireplaces, which should be relatively close to an older furnace...the gas valves in most current gas fireplaces use around 30,000 BTU's a day = about 110 therms a year. A NG therm costs constantly change but can routinely cost anywhere from 1.00 to 1.50. End result is about $100 to $150 a year. We(fireplace supplier) usually quote $10 to $12 to operate a NG pilot.
Interesting. I found another quote where it stated that furnace pilots use between 5 & 12 therms per month.
V
veesubotee is offline   Reply With Quote
Old 11-24-2008, 07:22 PM   #17
V
Don't you get it that some pilots orifice openings are larger than others hence the differences?
hvaclover is offline   Reply With Quote
Old 11-24-2008, 08:41 PM   #18
110 therms per year = 9 per month. 5 to 12 therms per month sounds correct depending on the pilot.
Martinglmt is offline   Reply With Quote
Old 11-25-2008, 01:39 AM   #19
An old Tradesmen
Rewards Points: 8,174
Bottom line is.
Pilots are highly wastefull.
Kinda like the Big 3 using their private coporate jets to tell Congress they need 25 billion dollars to stay a float.
Old 11-25-2008, 07:33 AM   #20
Rewards Points: 292
Kind of obvious.
Old 11-25-2008, 07:35 AM   #21
Rewards Points: 292
Yes, that's why I posted it.
V
Old 11-25-2008, 07:38 AM   #22
Rewards Points: 292
Originally Posted by beenthere View Post
Bottom line is.
Thanks, Been.
When I started this whole mess, I wanted to break out my non-heating gas usage (using summer months as baseline). I failed to take in account my pilot which had been running constantly.
V
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Lennox G11 Pilot light with not relight robbbb HVAC 6 07-17-2008 09:45 AM
Is a pilot light supose to stay on? simonb HVAC 2 06-11-2008 05:16 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 09:37 AM
hot pilot light supply line dlkk HVAC 1 02-24-2006 05:45 PM
