Standing Pilot In Carrier Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 08:34 PM   #1
standing pilot in carrier furnace
I have a pilot light that is intermittent. have replaced thermocouple, pilot assembly and gas valve. after the furnace runs for a few cycles the pilot goes out. is there a safety over ride in the valve that will shut off the pilot light?
Ronnie1010 is offline   Reply With Quote
Old 01-12-2011, 08:42 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
how old is this furnace? the heat exchanger may be cracked
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
Ronnie1010 (01-12-2011)
Old 01-12-2011, 09:04 PM   #3
HVAC / Plumbing
make sure the pilot just heats the tip of the t.couple. AS tech said . those old carrier heat exchangers were bad about cracks/ holes
kenmac is offline   Reply With Quote
The Following User Says Thank You to kenmac For This Useful Post:
Old 01-12-2011, 10:34 PM   #4
thanks, will check it in the morning
Older Carrier Pilot Burner Problem cliffkot HVAC 23 04-29-2011 06:58 PM
Pilot light going out often...and furnace making a big "boom" sound Beth777 HVAC 20 01-22-2011 05:27 PM
Carrier Furnace Series 160 Pilot Light issue eastons HVAC 2 03-15-2009 03:26 PM
Carrier 58MCA Furnace No Heat (Error 33) zerafah49 HVAC 1 12-10-2008 08:32 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
