Spring Coil Cleaning - HVAC - DIY Chatroom Home Improvement Forum
Old 04-13-2013, 12:11 PM   #1
Roofmaster
Rewards Points: 2,210
Hey All.
I want to clean my condenser and evaporator coil. What is the best product available to the lay person to do this? I use my pressure washer from inside out on my condenser with a wide fan so I don't damage the fins, but what is the best cleaner/surfactant I can use?
Is greased lightning any good? I have several large spray bottles of it.
Thank You.
Old 04-13-2013, 03:14 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 398
that may be corrosive. Simple Green/ citrus based cleaners are good.
The Following User Says Thank You to yuri For This Useful Post:
jagans (04-13-2013)
Old 04-13-2013, 08:16 PM   #3
Roofmaster
Thanks Yuri. Words from the Master. Will Do.
Old 04-14-2013, 03:56 AM   #4
biggles's Avatar
same amounts one to one mix .....in a spray bottle and do it dry top to bottom and go have coffee...come back and the condenser will be foam up bigtime...light hose spray again top to bottom (inside out) it will look like a new condenser... trick put water in bottle first then the cleaner light shake ....spray 6" away from condenser...it will foam up as soon as it hits the fins.. http://www.grainger.com/Grainger/VIR...&cm_vc=IDPRRZ1 rubber glows and no wind around.done commercial condensers the size of a garage door,and they come out mint.yours once a year in the spring won't kill the fins...then do a water only inside out in say july..works great on window units evap and cond coils
Old 04-14-2013, 05:00 AM   #5
An old Tradesmen
Rewards Points: 8,236
Simple green applied to both sides of the coil.
I prefer a foaming condense coil cleaner, as it pushes the dirt out.
Old 04-14-2013, 09:22 AM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 398
Should we start the firestorm about the Pro's and Con's of spine coils and how to burn them out/I mean clean them.
maybe that foam would work good for them.
plummen (04-14-2013)
Old 04-14-2013, 09:34 AM   #7
An old Tradesmen
Other then to say its an approved method. I won't tell someone how to do it.
Old 04-14-2013, 10:08 AM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 398
remember a couple yrs ago the fighting we had here about it. Can't believe how personal some guys take their commenting and perceived insults here and everywhere.
Old 04-14-2013, 10:10 AM   #9
An old Tradesmen
I remember.
Old 04-14-2013, 10:14 AM   #10
Hvac Pro
yuri's Avatar
Rewards Points: 398
I just got some weird pop up which hopefully is not linked to this page. said I was running microsoft antivirus whcih I don't, I use McAfee and have MS disabled and wanted me to run a scanner program to remove viruses and prevent "breakage". sounds like foreign hackers. I closed out everything and am running a full scan. hopefully no one else gets it.
Old 04-14-2013, 10:17 AM   #11
An old Tradesmen
I use malware and defender pro.
Old 04-14-2013, 10:35 AM   #12
Hvac Pro
yuri's Avatar
Rewards Points: 398
I get McAfee free with my service and had Norton before which I paid for and both worked perfectly. Use a router too which helps a lot as it blocks incoming unless you ask for it.
New A/C for Ranch - Separate Air Handler vs Evaporator Coil in Furnace scotzz HVAC 7 03-26-2013 03:53 PM
Ever install a door spring on a 2 door? noquacks Automotive Repairs 19 09-17-2011 06:29 AM
Spring Cleaning Acorns bigbavarian Landscaping & Lawn Care 10 04-28-2010 08:27 AM
Which way should coil face. firedogut HVAC 0 10-09-2009 09:58 PM
Evap coil question merlinfolks HVAC 15 07-27-2009 07:20 AM
