Old 10-30-2009, 06:42 PM   #1
Question Splitting duct to a new bathroom
I am drawing up plans to build a bathroom in my basement and am trying to determine how this space should be heated. Currently the basement is unfinished and there is a duct that runs to my upstairs bathroom - which is directly over top of my downstairs bathroom. The duct work is rectangular and the upstairs has a large old style grate cover. Is it possible to split this duct to run heat to both bathrooms? Thanks!
nalishaw is offline   Reply With Quote
Old 10-30-2009, 06:56 PM   #2
It would be possible to split the duct to serve both bathrooms but most likely it will be incorrect. Then the original ducts were sized, the were sized according to the amount of cubic feet in each room. If you tap in to that duct, you will be taking away from the upstairs bathroom and the airflow to the upstairs would be inadequate. If you decide to split the duct, you will have to follow that duct back to the unit and enlarge the duct up to the splitting point.
thehvacguy is offline   Reply With Quote
Old 10-31-2009, 12:09 AM   #3
An old Tradesmen
Guessing the basement bathroom won't be used much.
Use an electric heater.
Splitting the duct like you want. It would not keep the lower bathroom warm.
The cold air from upstairs will fall into the the lower bathroom. And the warm air from the lower bathroom would rise to the upper floor room.
Old 10-31-2009, 01:54 PM   #4
That is true, you have a very good point there.
Old 10-31-2009, 03:22 PM   #5
Old Newbie
Another thing to consider is sound transfer.
tinmanrob is offline   Reply With Quote
More On This Topic
Hi, this is Jon on behalf of Expert Village. In this video clip we'll be calculating volume of a room. In this bathroom we're going to be replacing the old exhaust fan. We need to calculate the volume of the room to know what size fan to buy. We're going... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test in this house. The reason we are setting up another duct blasting, we are going to go ahead and test the duct work again. You... Read More »
Creating delicious meals for the family at home also creates tantalizing aromas in the air. However, you need proper air ventilation to remove odors from grease, smoke and moisture. Whether you're redoing your kitchen or building a new home, several... Read More »
Diamonds are forever and a girl's best friend. You've heard all the sayings about diamonds, but nothing comes as close to the diamond as a cubic zirconia, a popular imitation that's much less expensive than the real thing. It's hard for the untrained eye... Read More »
This is Shannon Kniep on behalf of Expert Village. Before you put your sheetrock on, you want to go ahead and make sure that you've got everything taken care of because you're going to cover it up. In this case, we need insulation on our pipes--this is a... Read More »
Regular duct tape for bathroom exhaust? dtran HVAC 1 10-27-2009 05:26 AM
Splitting HVAC flex duct dphens HVAC 16 08-19-2009 04:47 PM
flex duct termination issue LanterDan HVAC 2 02-12-2009 07:59 AM
Venting bathroom vent thru dryer duct jredrocker HVAC 2 09-28-2008 12:25 AM
kitchen wall and bathroom fans sharing duct amakarevic Building & Construction 5 06-11-2008 02:13 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
