Split Unit Install - HVAC - DIY Chatroom Home Improvement Forum
Old 07-29-2013, 07:02 PM   #1
Split Unit Install
=) Thanks
Stephan85 is offline   Reply With Quote
Old 07-29-2013, 07:07 PM   #2
=) Thanks
Old 07-29-2013, 09:10 PM   #3
An old Tradesmen
Rewards Points: 6,140
Did you try downloading an English version from their website.
If you can't find an English version on their site. You can download it in Spanish. And then use Google translate, to translate it to English.
Old 07-29-2013, 09:16 PM   #4
Tried that, but it's so vague and pretty much just says Open, Hookup, Close it!
The connection between the handler and the compressor all I see. I see nothing for any input power. The only thing I can think of is doubling on the pins, but that is normally a no no...
Old 07-29-2013, 09:16 PM   #5
https://mirage.egnyte.com/h-s/20110531/d703c6c7b6d34579 is the URL to the manual in spanish.
230v from split unit a/c to receptacle Def.Eah Electrical 12 06-15-2013 09:52 PM
Resurrecting a Gas Heater - Questions about unit Jaxx HVAC 2 01-20-2013 03:52 PM
Rusted and almost gone drain pan, Package unit Nordyne kilosos2 HVAC 3 11-18-2012 10:24 AM
Noisy Fujitsu split unit Dmancol HVAC 1 01-16-2010 08:28 AM
mini split install bmancanfly HVAC 1 06-01-2009 04:57 PM
