Split System, High Humidity - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 09:57 PM   #31
An old Tradesmen
Rewards Points: 6,108
The EIM of the Yh9421 needs a constant 24 volts, Its mounted at the indoor unit. The stat on the wall is fed from the EIM, but it only uses 3 wires.
Old 08-18-2011, 10:48 PM   #32
Yea, thats the current set up as well, but I have separate heat and I shutdown the Air Handler in the winter by the main breaker. I was thinking about installing an alternate power source a 110 to 24 volt AC converter. The converter would be on a separate line then the Air handler.
Do you see an issue with that?
pauli is offline   Reply With Quote
Old 08-19-2011, 05:09 AM   #33
An old Tradesmen
Other then it making additional wiring work, no problem doing that. Why do you shut off the power to the air handler.
Old 08-19-2011, 08:10 AM   #34
My furnace is a oil fired, hot water radiator type, The air handler is separate and is in the attic. Can't see a reason to waste the electricity during the winter.
Old 08-19-2011, 05:20 PM   #35
An old Tradesmen
The transformer in the air handler in the attic doesn't use much electric. Using another transformer instead will use just as much electric.
High humidity in house in winter reddog General DIY Discussions 7 06-28-2011 06:38 PM
high humidity in my house mfinley HVAC 1 06-23-2010 06:55 PM
high humidity inside my house mfinley Building & Construction 1 06-22-2010 05:03 PM
beware humidity system? Emaderton3 HVAC 5 02-11-2010 12:52 AM
High humidity (RH) spm25 HVAC 3 11-06-2009 08:50 AM
