Split System Component Matching - HVAC - DIY Chatroom Home Improvement Forum
Old 05-03-2014, 04:06 PM   #1
Wink
Dear Forum,
I am considering two systems for a 2 ton Goodman 16 Seer. They use different components. Could someone give some guidance as to which is better (or correct!)
Model# Condenser -SSZ160241 +
Model# Variable Speed Modular Blower-MBVC1600AA-1 +
Model# Horizontal Cased Coil- CHPF3642C6
or
SSZ160241 + MBVC1200 (Blower) + CAPF3636B6 (Coil)
My line set is 3/8 & 3/4. This is a match for the first system, but the second uses 3/8 & 7/8.
Thanks!
Mike
Cburg1 is offline   Reply With Quote
Old 05-05-2014, 04:07 AM   #2
An old Tradesmen
Rewards Points: 6,846
Better in what manor. For efficiency, or for humidity control.
Need help verifying wirining on old split system mhoward223 HVAC 4 04-29-2013 06:57 AM
Installing Pool System New v. Used? flowerchick General DIY Discussions 5 10-27-2011 07:28 AM
Split System Marvel HVAC 0 10-24-2011 08:03 AM
Whats a good 3ton Heat-Pump split system to buy? ehoez HVAC 6 07-14-2011 09:11 AM
5 Ton split system keeps shutting down mahjohn HVAC 1 06-10-2006 07:31 AM
