Split Level House All A/C Going Downstairs - HVAC - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 01:29 PM   #1
split level house all A/C going downstairs
Hello,
I'm new to the site but have been lurking for a while...wondering if anyone else here has the same house design, its a difficult house to keep everything a consistent temp...we had a new Carrier ultra 95 put in last fall it handles both heat and AC...attic was recently insulated (spray foam gaps and about 14 inches of cellulose) wondering if i should put a door going downstairs (main level going down to ground level) the only thing is it will kill the open design, but i'm running out of ideas
thanks,
Brent
BKphoto is offline   Reply With Quote
Old 05-02-2010, 09:08 PM   #2
An old Tradesmen
Rewards Points: 6,836
How is the throw from your supply registers. Does the air hit the ceiling?
Old 05-02-2010, 09:52 PM   #3
they aren't in the floor...the are at the bottom of the walls, about 6 inches from the floor.
Old 05-03-2010, 04:45 AM   #4
An old Tradesmen
Go to Lowes or HD and buy those plastic deflectors to put on the registers that throws the air up.
The Following User Says Thank You to beenthere For This Useful Post:
BKphoto (05-03-2010)
Old 05-03-2010, 07:12 AM   #5
Rewards Points: 161
I have a similar house design and I found that running the blower fan continuously helps to even out the temperatures throughout the house. I also closed a couple of the lower air vents to force more air out of the upstairs registers. To run the blower continuously just turn the fan to "on" on the thermostat.
kb3ca is online now   Reply With Quote
Old 05-03-2010, 01:25 PM   #6
Rewards Points: 280
BT makes a good point.
I have a few of those clear plastic deflectors on my vents. In the winter I put them downstairs to deflect air out into the room vs up, since the hot air wants to rise naturally. In the summer, I move them upstairs to push the air across the ceiling vs down at the floor since cold air wants to fall.
I also had an additional air return added to the upstairs ceiling. If helps remove the hot air sitting on the ceiling.
As noted by kb3ca, I also run the air handler fan to circulate air. It's a vairable speed AH, so the fan runs at a very low speed.
Earnie is offline   Reply With Quote
Old 05-03-2010, 04:23 PM   #7
just got the deflectors today, definitely feel a difference...thanks, this house design is definitely a challenge...the system layout is set up more for heat than AC...
Brent
Old 05-04-2010, 06:31 AM   #8
Rewards Points: 280
Yes, two story/split level are a challenge to cool or heat.
I owned a two story house that had a real design/installation problem. Each floor had it's own heat pump system. The downstairs thermostat was at the bottom of the stairs and the upstairs thermostat was at the top of the stairs.
In the Summer, the cool air from the upstairs system would naturally fall down the stairway and prevent the downstairs system from turning On.
In Winter it was the opposite. Warm air from the downstairs system would naturally rise up the stairway and keep the upstairs unit from turning On.
I sold the house before the problem was corrected so I have no idea if it was ever fixed.
One more reason for all these Do-It-Yourself forums.
Old 05-04-2010, 08:22 AM   #9
yeah, i can see this forum helping a lot....i'm trying everything before i resort to putting a door in...the deflectors have helped a lot, i'm surprised...25 bucks, not a bad investment
How to Level subfloor? JPT Flooring 4 11-16-2009 09:51 AM
Hardwood flooring on stairs / split level Badger_DIYer Flooring 4 03-20-2009 05:00 PM
Is it ok to run on a treadmill on the 2nd floor of my split level home? J187 Building & Construction 5 02-09-2009 09:22 AM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
