Old 08-08-2011, 10:55 AM   #1
split installation
I have bought one LG duct type split unit for my apartment.
Its model is TBH366GSS1.Its' liquid and gas piping connections are 1/4 and 5/8.
The previously installed pipes of my apartment are 3/8 and 5/8.
Is it ok to use reducer connector and install it by previously installed pipes?
farad is offline   Reply With Quote
Old 08-08-2011, 02:11 PM   #2
Hvac Pro
split installation
if it is a mini split then NO as the liquid line is used as a capillary line. I would replace both of them so you get no leftover oil or contaminants from the old unit into your expensive new unit.
Sewage grinder pit and pump installation leff1rj Plumbing 15 02-04-2011 12:36 PM
Split floor joist scottyv81 Building & Construction 6 12-23-2010 03:42 PM
Repairing Split in Wood Door? diyintexas Carpentry 4 10-11-2009 02:00 AM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
