Split Ac Versus In Wall - HVAC - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 07:45 PM   #1
Rewards Points: 878
Split ac versus in wall
Ok me and the wife were gonna get the split unit but it is a bit expensive (~2k) plus install for 24,000 btu. We had an in wall unit previously but it was so loud hence the reason for the quiet split unit. Well the split unit is a bit too pricey for us. Are there in-wall units that are quiet?thanks
Mstrlucky74 is offline   Reply With Quote
Old 07-06-2013, 08:55 PM   #2
Rewards Points: 14,290
Did you factor in the cost to run it?
My power bills went down about 50 % when I switched from window units and a gas heater to a mini split heat pump in the summer and winter.
Old 07-07-2013, 10:56 AM   #3
Rewards Points: 878
THanks Joe!! We would be doing cooling only and looking at the electrical draw of a 24k btu split versus wall unit it looks to be about the same. Don't see how we would save 50% replacing one wall(cool only) with a split unit(cool only). I guess because you had gas heating as well and a few units you reached the 50% mark.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
How to add temporary support to this wall (to open up this wall)? jsunsun Building & Construction 7 01-20-2013 09:36 PM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
