Spine Fin Coils - HVAC - DIY Chatroom Home Improvement Forum
Closed Thread
Old 02-02-2012, 08:55 PM   #1
Rewards Points: 156
Spine fin coils
The American - Standard heat pump I have has spine fin coils in the outdoor unit. I remember my grandmother's house had several old GE zone-line units in it and they all had spine fin coils both on the indoor and outdoor sides. GE window and PTAC units now use conventional plate fin coils. Trane seems to be the exclusive builder of these style coils now. What happened to GE using these? Why don't any other manufacturers use this style coil?
av-geek is offline
Old 02-03-2012, 04:35 AM   #2
An old Tradesmen
Rewards Points: 7,832
Trane bought out GE.
Cost more to make.
beenthere is online now
Old 02-03-2012, 07:54 AM   #3
when a spine fin coil is new its very efficient, when it gets dirty it loses its efficiency x 10, here is a perfect example of DIRTY
harleyrider is offline
Old 02-03-2012, 01:12 PM   #4
Willing to listen
Rewards Points: 223
Torch that coil.
Done That is offline
Old 02-03-2012, 03:51 PM   #5
Originally Posted by Done That View Post
Torch that coil.
if you did that while working for me, you wouldn't be working for me the next day...........do you know what it cost to re-side a house after you burn up the vinyl siding? smart, well educated people do not play with fire.
The Following User Says Thank You to harleyrider For This Useful Post:
Plumber101 (02-03-2012)
Old 02-04-2012, 06:26 AM   #6
Rewards Points: 1,216
Still good you can still see the coil wrap lines. Special brush to clean them I used to work on GE's many moons ago that had them coils the brush is a roller type that looks almost like the coils them selves it gets right in the spines and pulls the dirt out.
COLDIRON is offline
Old 02-04-2012, 06:59 AM   #7
we use coil cleaner and a garden hose, no one's house gets burnt down and no one gets hurt. (except the homeowners wallet)
Old 02-04-2012, 07:18 AM   #8
HVAC Tech/ Browns Fan
You need get a wire brush and pull all that off then take hose to it. Please make sure breaker is off when doing it.
Tator1076 is offline
Old 02-04-2012, 07:19 AM   #9
Torch that coil.
Wow you are joking right?
Old 02-04-2012, 07:24 AM   #10
biggles's Avatar
commercially saw GE rooftop heat pumps with the spine condensers not a favorite of HVAC guys the worst thing in cleaning is to touch them...wonder if they call for a stronger condenser fan motor to pull air thru them vs a standard coil
biggles is offline
Old 02-04-2012, 08:40 AM   #11
Ace, as a rookie I flipped when I saw one of the older techs doing that. But then i got my first "cotton wood job". you can easily burn the condenser clean with a low flame on propane or mapp. It is safe for the condenser and and does not make a big burning bon-fire.
To the other Pros I say, "Don't knock it 'til you've tried it".
hvac5646 is offline
Old 02-04-2012, 09:27 AM   #12
Cottonwood is our state tree...I hate those coils.
Marty S. is offline
Old 02-04-2012, 10:02 AM   #13
Houston204's Avatar
Rewards Points: 556
I dread cleaning those coils too. I hate to see aluminum bristles on the ground if I have to use coil cleaner on an older unit.
The instructor in a Trane class I took spoke of using a torch to clean them but I thought he was joking.
I'd be interested in watching a video of this procedure performed successfully.
Houston204 is offline
Old 02-04-2012, 10:27 AM   #14
Scottphys's Avatar
WOW! I'm not an HVAC guy but I've never seen a coil that bad before. Seems preventative maintenance is the key for spine coils- Periodically hose-down.
In any case, wouldn't torching risk creating acid in the line set?
Scottphys is offline
Old 02-04-2012, 10:32 AM   #15
If you play with fire you get burned, if you play with fire on my payroll, you get FIRED !
Closed Thread
How to clean evaporator coils loftezy HVAC 13 12-22-2011 09:41 AM
Heat coils on same time w/ AC reevtd HVAC 9 03-09-2011 04:58 PM
Seer 10 evap coils bad, Go to Seer 13??? pcumming HVAC 5 09-01-2010 05:21 PM
Coleman Leaky Coils rdwacw HVAC 1 07-15-2010 10:30 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
