Spend $400 On Heat Gain Calc For 2nd Floor A/C? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-28-2013, 11:13 PM   #1
spend $400 on heat gain calc for 2nd floor A/C?
I contacted three companies for a/c quotes. Two gave them to me right away. the third company said I needed to spend $400 dollars to get a heat gain calc so he could properly quote the right system ie 2 1/2 ton, 3 1/2 ton. etc.
The quick question is, is the third guy right? and the other two companies shooting from the hip? Or is the third guy overdoing it? $400 isn't a trivial amount.
We're only looking for a/c for the second floor bedrooms thru the attic thru the second floor ceiling, (we have radiators.) we don't' want ductless units in each room thru the wall.
Its an 1930 old house with no insulation and original bad windows. We know its a leaky house.
Master bedroom 14x18
other three bedrooms, 12x10
2nd floor hallway 14 x 10
Thanks!
JP
jpjuggler is offline   Reply With Quote
Old 05-28-2013, 11:17 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
as with all quotes, you'd need three heat load calculations to get an average. what one guy inputs could be completely different than what the other two guys do. I've yet to hear of any two contractors coming to the exact same conclusion on any one dwelling.
but if the home is older and you've done work to it to seal the envelope such as insulation and/or double pane windows than it wouldn't hurt. you definitely do not want an over sized system.
what we need to know is the whole house heat load. that or simply ask the home owner how the past a/c system(s) worked and for how long, how many years? any mildew or mold issues? what were the run times inbetween cycling on and off? things like that to get a "feel" for if they were sized properly. Any whistling at the returns or supply vents? etc., etc.,...
Thanks.
Doc Holliday is offline   Reply With Quote
The Following 2 Users Say Thank You to Doc Holliday For This Useful Post:
HVAC1000 (05-28-2013), jpjuggler (05-29-2013)
Old 05-29-2013, 02:25 AM   #3
So, what does the company that you work for do when installing a system? Have three different employees do a load calc, or have the customer request this from two additional companies? Sounds odd to me.
hvac benny is offline   Reply With Quote
The Following User Says Thank You to hvac benny For This Useful Post:
Old 05-29-2013, 02:49 AM   #4
FClef's Avatar
Rewards Points: 160
People charge for heat loss calculations? Really?
A lot of supply houses do them for free for the contractors.
FClef is offline   Reply With Quote
The Following User Says Thank You to FClef For This Useful Post:
Old 05-29-2013, 07:08 AM   #5
thanks for the reply and my original question still stands..
should I spend $400 on heat gain calc for 2nd floor A/C? And is the third guy right, and the other two wrong, or vice versa.
The system is only to do the 2nd floor, the house has no a/c installed now.
from before......
Old 05-29-2013, 08:03 AM   #6
HVAC Tech/Owner
Rewards Points: 604
Absolutely-we charge for the calculations if the homeowner wants the results WITHOUT a signed contract for the replacement.
I know our calcs are highly accurate room by room and I would question a "supply house" doing an accurate calc from their office desk.
Technow is offline   Reply With Quote
The Following User Says Thank You to Technow For This Useful Post:
Old 05-29-2013, 08:03 AM   #7
what's odd is that with all the science involved in a heat load, hard headed hvac techs and contractors don't ever see eye to eye on the calculation and NEVER come to the same conclusion.
it is printed on our service tickets that heat loads are strongly recommended for COMPLETE system change outs but no one ever goes for it as no one is willing to pay for it and no, it's not free. We simply change out like for like in most instances but I can't say how many times a complete system has been installed, mostly and on my end it's one piece, no heat load required.
Thanks.
The Following User Says Thank You to Doc Holliday For This Useful Post:
Old 05-29-2013, 08:28 AM   #8
so the other two hvac contractors are wrong not to do a heat gain calculation I take it, even thought its just for the second floor bedrooms...?
Old 05-29-2013, 03:55 PM   #9
Rewards Points: 242
the ones that don't do a heat load calc. probally doesnt know how.
hvac instructor is offline   Reply With Quote
The Following User Says Thank You to hvac instructor For This Useful Post:
Old 05-29-2013, 06:37 PM   #10
Hvac Pro
yuri's Avatar
Rewards Points: 1,156
$400 sounds high. Even if his company charges $100/hr it does not take 4 hours to do one. 2 max. DIY at this site and see how close you come.
http://www.hvaccomputer.com/gtarget1...Fe4-MgodPF4AoQ
The Following User Says Thank You to yuri For This Useful Post:
jpjuggler (05-30-2013)
Old 05-29-2013, 10:12 PM   #11
An old Tradesmen
Rewards Points: 6,140
While the other 2 are some what wrong. Your talking bout 512 sq ft. Doubt it needs more then 1.5 tons. And you won't find a 1 ton conventional split unit. Save the 400 bucks.
The Following 3 Users Say Thank You to beenthere For This Useful Post:
gregzoll (06-04-2013), hvac instructor (05-29-2013), jpjuggler (05-30-2013)
Old 05-29-2013, 10:17 PM   #12
DIY Enthusiast
sublime2's Avatar
GOOD advice!
Take it.
sublime2 is offline   Reply With Quote
Old 06-04-2013, 06:41 PM   #13
MarginallyQualified
Rewards Points: 2,464
Originally Posted by yuri View Post
You cannot expect (HVAC contractors) to have laptop computers with expensive heat load calc software and take the time to satisfy a very few tech savy customers.
I never said it should be their job to do this.
If anything... I'm saying that the HVAC contractors are the LAST ones to be doing this.
Homeowners need an objective 3rd party to write the spec.
Someone who doesn't have a $5-$15,000 job on the line.
Armed with the spec... they can knowledgeably shop the work.
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Low-E in the Northeast. Clutchcargo Building & Construction 11 10-28-2008 08:34 AM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
Heat Loss Gain how to calculate jufix HVAC 1 11-20-2007 03:46 PM
