SPace Pak Air Handler Wiring Question--208-230/60/1 - HVAC - DIY Chatroom Home Improvement Forum
Old 05-04-2009, 11:01 PM   #1
Quick question-
I currently have a 12-2 gauge wire (black, white and copper) running from the basement to the air handler up in the attic.
The Air handler calls for a 208-230/60/1 power supply.
The high voltage block on the air handler has an L1, L2, N and a grounding lug on it.
Question:
How do I connect the wire at the CB panel and the air handler?
Here is what I was thinking....
Get a 20 Amp double pole CB and connect the BLACK and WHITE lines to the CB and the copper ground to the nuetral bus bar at the CB panel. Then at the air handler, connect the black wire feed to the L1 terminal, the white wire to the L2 terminal, and the copper to grounding Lug.
Does this sound right?
metal121 is offline   Reply With Quote
Old 05-06-2009, 05:14 AM   #2
yuppers
assuming of course its a/c only (couldnt remember if spacepacs could have elec heat)
kennzz05 is offline   Reply With Quote
Old 05-06-2009, 06:57 AM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
By what you say, you're going to need a 12/3. Black to L1, Red To L2, white to N, and ground to ground.
Sounds like this unit has 240 volt loads as well as 120 volt loads. To the breaker, Black/red to breaker, white and ground to their respective bars.
The way you have it, 120 volt loads won't run.
wirenut1110 is offline   Reply With Quote
Old 05-06-2009, 11:42 AM   #4
The unit is a/c only....Im not running heat...only cooling.
Here is what the service manual says:
"Connect power supply to Terminals L1 and L2 on the high
voltage terminal block. Connect a ground wire to the
equipment ground terminal located next to the high voltage
terminal block."
It says nothing about connecting a white nuetral.
Thoughts? Im thinking I dont need 110v and the 12-2 is all that is required for the 208-230/60/1 wiring.
Here is a picture:
Old 05-06-2009, 03:44 PM   #5
An old Tradesmen
Rewards Points: 7,356
No neutral needed.
Old 05-07-2009, 05:52 AM   #6
Rewards Points: 510
Yep, according to the drawing, no neutral. I was just going by what you were saying in post #1. Good to go.
low-voltage and electrical wiring sharing same stud space jheavner Electrical 21 10-06-2011 11:16 AM
whirlpool icemaker wiring question dannyb Appliances 3 03-28-2009 08:45 PM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 05:44 AM
240/208 Heater wiring Question fburke Electrical 2 06-20-2005 12:09 PM
New fixture wiring question Unregistered Electrical 1 02-22-2004 07:34 PM
