Old 09-21-2012, 06:33 PM   #1
Soundproofing air conditioning unit
I live in a condo and part of the A/C units are on the roof. Part of the unit is in the ceiling of the actual unit. When the A/C turns on it is loud, it is not broken but it just isn't a quiet unit. In my ceiling, there is a drop down metal door that is about 54" by 28" with an air intake grate of about 18" x 18" in the middle. This is where I change my air filter. Is there any way to add soundproofing to the 54" by 28" metal drop down door. Naturally, I would have to leave a hole to let the air in so I was wondering if soundproofing the metal drop down door minus the intake would help reduce noise and if so what kind of soundproofing material should I get?
grand_canyon is offline   Reply With Quote
Old 09-21-2012, 06:51 PM   #2
I'm Your Huckleberry
Called a furr down unit, where the blower is in the ceiling. Used in condos and apts. Very common.
Not certain what can be done as far as soundproofing but the blower may be able to be lowered in speed. This would quiet the system down IF that blower motor can indeed be slowed down.
In residential applications where the return air grill is located close to the blower we can (and have) extend the duct, loop it around in the attic for quietness. So although the duct run from the blower to the return only needs to be let's say 6' we can run it 15'-20', 10' out and away from the return and then 10' back and then connected to the return, where the filter is. This dampens the noise greatly. The longer the duct, the less noise. In your situation that is out of the question.
And I don't know of anything that can be done as far as literal soundproofing.
Thanks.
Doc Holliday is offline   Reply With Quote
moving central air conditioning unit coopeli HVAC 10 10-05-2011 05:34 PM
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 08:05 AM
Help! How do I reduce lateral sway or wobble in a shelf unit? sfsdfd Carpentry 9 07-15-2011 03:29 PM
What is the price difference between a 2.5 ton unit and a 3 ton unit? Leoskee Off Topic 2 03-27-2010 08:13 PM
Bryant Air Conditioning Unit ARTLEE HVAC 1 07-01-2007 08:22 AM
