SOS - AC Condensor Fan Stop Working When Tempreture Is Over 103 Outside - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-24-2011, 03:36 PM   #16
JJboy's Avatar
Originally Posted by bjch512 View Post
Hi,
Thank you all so much for your help.
I manually move the blades one more time. This time I move it a lot with a stick, and this time the blades start spining iteself after I manually move it. We have cool air now. Yea
Can we say for sure now the problem is the motor run capacitor? Also, could someone please tell me where I can buy a motor run capacitor in Austin, Texas? I can order one from eBay but we have to wait for many days for it to arrive.
Thanks & regards,
bj
I'm in Austin. What is the capacitor value?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-24-2011, 03:39 PM   #17
Originally Posted by REP View Post
The vast majority of times in situations like this it is the capcitor.It is also the least expensive of the two possibilities.Capacitors come in various sizes to match the motor they are working on.The new one must match the need exactly.There is also a voltage after the UF number and if yours is 370.you can use a 440 but not the other way around.
You may also have a dual capacitor uin which the fan is on one side and the compressor is on the other side.If you get a new one,the same advice is true you must match the UF factor exactly but you can go up to 440 on the voltage.
Do not run the a/c until you have fixed the problem.Only bad things can happen if you do.
Thanks for your advices. I have turned off the AC.
The only question I have now is where I can possibly buy a motor run capacitor in Ausitn, Texas. I google it but fail to find useful information
Thanks & regards,
bj
bjch512 is offline   Reply With Quote
Old 07-24-2011, 03:42 PM   #18
Let me open the unit and see what is the value.
Thanks & regards,
Lee
Old 07-24-2011, 04:53 PM   #19
Ok, finaly got it.
There are 2 seperate capacitors inside the unit:
(1) 135-162 MFD, 330 VAC. This one looks fine visually.
(2) This is a dual capacitors in one unit with three terminals: "C", "FAN" and "HERM". One end (the one with terminals) of the capacitor is swelled that is a sign for bad capacitor. The value is: 5 MFD + 25 MFD, 440 VAC.
Old 07-24-2011, 04:59 PM   #20
Ok, finaly got it.
Two things I don't understand are:
Q1: Why I have 3 capacitors (1 indivisual capacitor and 1 dual-capacitors in one) in the unit? If I understand right, most AC boxes outside only need 2 capacitors. One for fan and one for condensor.
Q2: My understanding is terminal "C" is common, "FAN is for fan motor and "HERM" is for condensor. Since the dual-capacitor unit looks bad (swelled). Why fan doesn't work but condensor is still working okay?
Thanks & regards,
bj
Old 07-24-2011, 05:06 PM   #21
JJboy's Avatar
You need 25/5 MFD 440V. I have one. I'm in North. Where do you live?
Old 07-24-2011, 05:12 PM   #22
I'm in 2222 & 620 area (northwest area).
If you don't mind, would you let me know how much I should pay for it?
Thanks & regards,
bj
Old 07-24-2011, 05:19 PM   #23
JJboy's Avatar
http://www.grainger.com/Grainger/PRO...MZ0?Pid=search
Old 07-24-2011, 05:24 PM   #24
Very fair price. Would you let me know how I can get it?
Thanks & regards,
bj
Old 07-24-2011, 05:31 PM   #25
JJboy's Avatar
you can stop by in my house to pick it up
Old 07-24-2011, 05:35 PM   #26
Would you email me your address if you don't mind? I can come over now if it's conviniece for you.
My email is:
L_X2828@YAHOO.COM (there is an underscore between L and X)
Thanks & regards,
bj
Old 07-24-2011, 05:40 PM   #27
JJboy's Avatar
check your e-mail
Old 07-24-2011, 05:45 PM   #28
check your e-mail
Hmm...have you sent it out? I still don't receive it. Or maybe you can text your address to my cell? (512) 934-8603
Thanks & regards,
bj
Old 07-24-2011, 05:48 PM   #29
JJboy's Avatar
Yes, I also sent a msg.
Old 07-24-2011, 07:50 PM   #30
REP
Well good,somebody is going to be cool tonight.
NOTE don't forget to label the wires so you get them back on the right way!!!!!!!!!!
REP is offline   Reply With Quote
low slope roof want stop leaking kaju Roofing/Siding 22 09-14-2012 01:19 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 03:45 PM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 08:00 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
