Old 11-18-2007, 11:20 AM   #1
son's room too hot
we have baseboard hot water (oil furnace)
thermostat is on the first floor (not zoned) - bedrooms are on the second floor
our room temp is fine but out son's room (right next to ours) gets too hot. I have a ceiling fan on but this does not help. in our room we have one baseboard....but....in his there are 3 baseboards. is there anyway to "shutdown" 2 of them (the end and middle basboard)?
nit10elions is offline   Reply With Quote
Old 11-18-2007, 12:25 PM   #2
Electrician
son's room too hot
I believe most baseboard heat has some type of louvers installed to dampen the output of the heat...
chris75 is offline   Reply With Quote
Old 11-18-2007, 06:40 PM   #3
son's room too hot
anyone else know for sure?
Old 11-18-2007, 08:01 PM   #4
Custom Cabinet Maker
son's room too hot
baseboard has louvers at top of slot, close em. It will cutdown a large amount of heat flow but it will NOT stop all of it. Only real way is to re pipe the system and split it into separate zones. That will be expensive.
Answer to the question you have not asked YET: NO you cannot put valves into the system to isolate those heaters, that will shut down the entire heat loop. BUT WAIT Yes here is next best solution; you can, shut down system, cut the tube and fin out of all the baseboard, run straight pc of pipe, reconnect the run, that is about all you can do without redoing entire system
skymaster is offline   Reply With Quote
Old 11-21-2007, 08:35 PM   #5
son's room too hot
thanks...the "louvers" solution worked. i closed 2 out of the 3 and he has not complained at all. very comforatable
Old 11-21-2007, 09:16 PM   #6
son's room too hot
You are most welcome
HAPPY TURKEY DAY (unless you are the turkey )
Laminate Flooring Flowing from Room to Room frskelly Flooring 1 09-16-2007 12:14 AM
My kids room is cold snmhanson HVAC 5 12-20-2006 12:51 PM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 04:08 PM
question about cleaning a boiler room Piratehart General Discussion 1 02-14-2006 01:58 PM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 04:33 PM
