Sometimes My Cenral AC Run And Sometimes Not Running - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-13-2013, 08:34 AM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
reread my last post as I added to it. not much I can do w/o being there but you should get a Pro. if the compressors burn out or get damaged then it is a $1500-2000 repair and most of the time better to get new units.
Old 08-13-2013, 08:37 AM   #17
Originally Posted by yuri View Post
you may have a larger problem like low voltage to the units or your house. both units should not have the same problem. that is VERY hard on the compressors and can damage them. may want to get a Pro to check them. you would need to check the voltage to them AND while it is trying to start. could be the compressor(s) are getting old (if they are old units) and seizing up and may need a hard start kit or you got other problems like a bad thermostatic expansion valve, burned contacts in the contactor, or damaged wiring at the compressor etc. sounds like a voltage problem too me. best to get a Pro to check them before some very expensive damage occurs.
I am sorry the AC system on my house is no split system. I have only one 5 ton system using upstair and downstair. It used the Damper to split the air. I am sorry to confuse you. One thermostat used on upstair and one downstair. Both thermostats used the same 5 ton AC unit. I have used this system for 9 years since it was installed and the only fix for it is the new evaporator coil replaced last year in september.
tuanngnt is offline   Reply With Quote
Old 08-13-2013, 08:41 AM   #18
Hvac Pro
yuri's Avatar
OK then it could be both thermostats are short cycling but that is unlikely, sounds too me like the compressor itself is having starting problems due to low voltage, burnt contactor or the other reasons I gave you. a 5 ton compressor may run you $2-3000 so as much as this is a DIY site getting a Pro may be your best bet. if it is zoned then you may have a combo zoning panel the thermostats talk to and that could be short cycling. not much I can do w/o being there.
Old 08-13-2013, 08:43 AM   #19
I think I should call the pro then. Thanks for the all info...
Old 08-13-2013, 08:45 AM   #20
Hvac Pro
yuri's Avatar
Good Luck. Get a good Pro as zoning systems are tricky and lots of guys don't understand them.
