Sometimes Air Handler Fan Not Coming On In "AUTO" - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 07:38 PM   #1
Sometimes air handler fan not coming on in "AUTO"
Hi everyone. New here and hoping to get some help. The problem I am having is that sometimes in "Auto" mode, the air handler blower fan doesn't run. Thermostat calls for heat, the furnace starts and the pipes are hot. The problem is that the blower fan doesn't start by itself if I set the fan to "Auto" mode. The problem doesn't always happen and it seems to happen more in the mornings. Initially I suspected that the problem may be with thermostat but replacing the thermostat did not help. If I turn it to the "FAN ON" position it works great but fan will not kick in automatically the "FAN AUTO" position. What should I do?
I called the oil company HVAC tech and when he came everything was working and he was not able to see the problem. Was charged $90 for the visit. I am hoping someone can help me here.
The air handler is made by FirstCo and is about 10 years old.
Model is 24MBXR-3HW
Fan coil Unit 27JF
dvsrikanth is offline   Reply With Quote
Old 12-08-2010, 08:13 PM   #2
JJboy's Avatar
Check the capacitor and blower fan terminals.
JJboy is offline   Reply With Quote
Old 12-08-2010, 08:27 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
there is probably a relay in the AH. The relay may be on a control board, or not. It may be failing. trace your wires back from the blower motor and find what they go to.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-09-2010, 10:56 AM   #4
yea sounds like the relay or fan switch going out. if its a fan switch check the setting on it to see when the fan is suppose to come on. if its a relay on the control board you have to replace the board to fix it.
hvac kid is offline   Reply With Quote
Old 01-06-2011, 09:35 PM   #5
Problem did not happen for 3 weeks and it started happening again.
I am a new home owner and I have little experience doing this kind of work.
What is the best way to check the fan switch? Is this the part (safety switch) that gets pushed inside when the blower cover is in place?
Is changing the board a DIY job? How difficult is it?
Fire ants coming into house through pipes in foundation -- need advice samalex Pest Control 15 03-22-2011 01:35 PM
Air handler blower doesn't work in "Auto" mode dvsrikanth HVAC 6 12-03-2010 01:13 PM
Heater fan not coming on in "AUTO" reptile411 HVAC 26 12-02-2010 10:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
