Hello, tonight a friend called and said her central air wasn't working. I went over there and discovered some dispicable person stole the pull-out breaker from the disconnect box.
Well, I looked all over the outside of the unit and didnt see a nameplate anywhere to get specs from. So my question is, how do I determine what size breaker was on the unit. The breaker for the a/c in the main box on the mobile home is a 30amp....would the outside disconnect be the same size? Will there be a stamping inside the disconnect box on the black inside that would say what size was in it?
The a/c was blank, but the furnace is an Intertherm 53000 BTU unit in a mobile home, and shes fairly certain the a/c is original to it. The a-coil is not mounted i the furnace, so I assume its in the outside unit.
