Soft LockOut - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By supers05
Old 02-17-2017, 10:10 AM   #1
Rewards Points: 4
Soft LockOut
Furance:
International Comfort products.
Model: T9mpt075f14c1
Symptoms:
Heats multiple times seems to stop heating at random and go into a soft lockout.
Troubleshoothing:
Replaced Flame sensor
Replaced MainBoard.
THoughts:
I have my step dad picking up a gas valvue.
Iv watched it try to cycle 3 or 4 times then go into a soft lockout.
One time we watched the system light and run and at one point the burners stop and it goes into a soft lock out.
Seems strange like it lost gas... thus the gas valve.
I've blown in all hoses and not seen any clogs or anything.
Board is replaced and worked good for 24 hours then starts to have the problem again at random.
My HVAC guy said to clean burners before replacing gas valvue. I also want to replace the Igniter as well.
This unit was built in 2008 and i dont think it was installed more than 6 years ago. Seems strange to be having these issues. From what i see it seems like its trying to start but no gas is being sent??? thus it trys 3 times then fails to sense flame or start so it goes into a soft lock out for 3 hours. In the past i could flip breaker and get it started right away but right now its not starting and i took a video of it.
areahall is offline   Reply With Quote
Old 02-17-2017, 10:10 AM   #2
Rewards Points: 4
Re: Soft LockOut
Here is the video:
Old 02-17-2017, 11:17 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,852
Re: Soft LockOut
You need to check the incoming gas pressure before the gas valve with a manometer. The specs are on the model# sticker.
Go to You Tube and search: "test furnace gas pressure" and there are good vids
You also need to check if you are getting gas from the valve when the igniter is glowing. I hear a click which may be the gas valve trying to open. Check if you are getting 24 volts AC at the gas valve terminals. Looks like a 2 stage valve so you need to test it across the low fire and C terminals.
Old 02-17-2017, 03:01 PM   #4
Rewards Points: 7,442
Re: Soft LockOut
I have a silly question:
Do other gas appliances work? if there are any other gas appliances?
The gas could be turned off at the meter from forgetting to pay the bill or accidentally at the furnace.
don't change the valve unless you know for sure it's bad. i actually would suggest leaving that sort of thing to a pro due to the risks.
if you do end up changing the valve yourself, you'll also have to check and possibly adjust manifold pressures.
My Backround FIY: I am not in the business of any trade or topic I give advise on. I have some have formal education in HVAC + some DIY experience. Theory is not a substitute for experience.
user_12345a is offline   Reply With Quote
Old 02-17-2017, 05:44 PM   #5
Rewards Points: 46
Re: Soft LockOut
You haven't mentioned if you cleaned/changed the flame sensor.
Cheers!
supers05 is offline   Reply With Quote
Old 02-17-2017, 07:18 PM   #6
Rewards Points: 46
Re: Soft LockOut
Never mind.... I finally got a chance to watch the video. Looks like the ignitor isn't getting hot enough. Replace the ignitor.
Cheers!
beenthere likes this.
weil mclaine ultra 155 series 3 boiler soft lockout mike1979 HVAC 0 02-03-2016 07:22 AM
soft copper pipe issues fred54 Plumbing 7 04-02-2013 05:53 AM
Soft lockout in Burnham Alpine 150 Billm10454 HVAC 5 01-01-2013 12:04 PM
Heil Gas Furance Soft Lockout nicole_d82 HVAC 1 09-16-2011 05:08 PM
Silver solder on previous soft solder joints GPS10 Plumbing 2 01-27-2010 04:34 PM
