Snydergeneral Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 09:50 AM   #1
snydergeneral furnace
After the burner has kicked off and the blower turns off the blower will kick back on about a minute later and run for about 30 seconds. What could be causing this?
tdtmann is offline   Reply With Quote
Old 11-10-2010, 07:27 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
blower on
your temp in the heat exchanger had dropped and cut the blower out, but residual heat caused the blower limit to call for blower again, no big deal, can be fixed by setting the limits in the control to different temps
hvactech126 is offline   Reply With Quote
Old 11-10-2010, 09:00 PM   #3
An old Tradesmen
Rewards Points: 8,202
Check your air filter.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
