Snyder General 90% Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2009, 01:35 PM   #1
snyder general 90% gas furnace
i have a 21 yr old 90% furnace never used model number is (guh075a012in) and only1 of the three burners come on i was woundering if i had to big of a air in take three inch pvc comeing in
t3rr3nc3 is offline   Reply With Quote
Old 01-10-2009, 02:25 PM   #2
Sounds more like a gas issue. Do you have lp or nat gas? Could also be obstructed burners or orfices.
SKIP4661 is offline   Reply With Quote
Old 01-10-2009, 06:38 PM   #3
natrual gas and if i light the other two it will come on
Old 01-10-2009, 06:58 PM   #4
nat and if i light it the othere two come on
Old 01-10-2009, 09:23 PM   #5
What do you mean "never used".
What you have is a corroded cross over and burners.
Assuming I am getting what you say (try using some freaking periods. makes it easier to read) the furnace was never used before. Correct?
Either way it has corrosion like i said and the burners cannot be field corrected.
I am a dealer for that brand (now owned by icp) and can speak authoritatively.
hvaclover is offline   Reply With Quote
Old 01-10-2009, 09:28 PM   #6
http://www.expertappliance.com/partfinder.php
heres the link.
Old 01-11-2009, 12:05 AM   #7
Lightbulb
ok,
what should i clean it whit ?
it is a three burner furnace,
the one on the right will light on and go off in about htree sec if i light the other then they will stay on.
Old 01-11-2009, 08:17 AM   #8
Read what I said.
Not field correctable. The burners were a bad design and corroded shut and stopped pass gas.
The burners are precision formed opening; they cant be drilled out or brushed out or the burner openings will be made too large and will pass more gas than is safe.
That means you have an explosion hazard.
You need to buy new burners.
Old 01-12-2009, 01:59 PM   #9
Question
burner
Originally Posted by hvaclover View Post
Read what I said.
do you know if the burners are sold as assamble.
and is it worth it?
Old 01-12-2009, 04:42 PM   #10
For what they want for the burners at that link I would have a tech install them. Probably cost about $300 to have a tech do it. But he will make sure the rest of the furnace is ok.
That model was a pain in the ass, not many of them around now. Had lots of issues.
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
snyder general gas furnace problem john duchaine HVAC 1 10-29-2008 05:31 PM
Snyder General Gas Furnace - No Gas to the ignitor Hanela HVAC 5 12-04-2006 11:37 AM
