Snyder General 1990 GUH Furnace Ignition Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 10-20-2011, 12:19 PM   #1
Snyder General 1990 GUH furnace ignition problem
PROBLEM: Main burner shut off as soon as blower turns on
DISCUSSION: I've checked the users manual and installation instructions concerning the above problem. I replaced the flame sensor after cleaning it off did not solve the issue. As soon as the fan and limit switch (older dial type) clicks to turn the blower on, flame goes out. At this point am I left with replacing the ignition module as the only possible solution left????
Thanks for the help!!!
tkacer is offline   Reply With Quote
Old 10-20-2011, 01:03 PM   #2
JJboy's Avatar
fan limit swtch
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-20-2011, 01:20 PM   #3
I thought the fan limit switch only controlled the blower fan. The main blower does turn on when it clicks at the on temp setpoint. Please elaborate - sorry for any obvious ignorance on my part....
Old 10-20-2011, 06:25 PM   #4
JJboy's Avatar
Check this link ==> http://arnoldservice.com/fan_blower_controls.htm
Old 10-20-2011, 08:42 PM   #5
Your combo fan/limit does both. If your "fan on" setting is set too close to the limit setting it is possible to kill the burners and energize the fan. That's what it's designed to do.
thestig3 is offline   Reply With Quote
Old 10-20-2011, 09:56 PM   #6
Rewards Points: 582
you could jump out the limit and see if problem changes... i do not think you have a bad ignition since burnners lite as they should ????
furnace burner problem ? diypete HVAC 2 03-22-2011 06:27 AM
Another Keeprite Electric furnace problem lrad Electrical 0 10-18-2010 12:24 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Miller G5RA furnace flame sensor problem mpit52 HVAC 3 01-16-2009 10:30 AM
Snyder General Gas Furnace - No Gas to the ignitor Hanela HVAC 5 12-04-2006 11:37 AM
